minie me timing
Old Jan 24, 2008 | 08:15 AM
ef-hatchcrap's Avatar
Default minie me timing
Ok I have a d15b2 block and a z6 head it runs but not well I think it is the timing I have the timing set like this ! ! ! ! I have the pointer on the 1 line and the cam set with the "up" up and the side marks line up is this correct.
Or should I set the pointer on the timing cover in the middle of the 3 lines?
Old Jan 24, 2008 | 09:22 AM
Default Re: minie me timing (ef-hatchcrap)
Old Jan 24, 2008 | 02:36 PM
24TEN's Avatar
PHANTOM MENACE
Sounds like you had it correct the first time. Quick question, are you using a stock cam gear or an adjustable cam gear?
Old Jan 24, 2008 | 02:50 PM
Default Re: minie me timing (24TEN)
Im using a stock cam gear. I had one on my last minie me and it was pointless. I never went and had it tuned. This is just a put together motor until my d1b gets here
Old Jan 24, 2008 | 02:56 PM
24TEN's Avatar
PHANTOM MENACE
Check the FAQ, I think you might have to use a newer cam gear to compensate for being off if you don't use an adj. cam gear.
Old Jan 24, 2008 | 10:00 PM
clubef9's Avatar
24TEN is correct. You need to use the Y7/Y8 cam gear to correct for the 4.75 degrees or half-tooth. Did this on ours and never had the "timing" issue. Good luck! D15 mini-me's rock!
Old Jan 25, 2008 | 12:45 PM
tibss's Avatar
Default Re: minie me timing (clubef9)
I don't mean to hijack yout thread but what does it do when you are running the stock cam gear?
89ED
18
Jun 22, 2018 03:38 AM
Ef4doorwagon
13
May 17, 2014 06:09 PM
EJ6sedan
Dec 22, 2009 01:27 PM
maddog20
Feb 4, 2008 09:24 AM
97grnrs
May 10, 2007 03:25 PM
