Classic Hondas All Pre-1988 Hondas.
3gen Quad Carb Setup?
Old Jan 24, 2008 | 06:58 AM
86punishment's Avatar
Default 3gen Quad Carb Setup?
I am thinking about retireing my 86 civic to the track and was wondering if anyone had info on doing a quad carb setup on one of these, or maybe a twin two barrel setup
Also will putting a headder on the stock motor lean it out too much?
Old Jan 24, 2008 | 01:08 PM
slavteren's Avatar
Default Re: 3gen Quad Carb Setup? (86punishment)
http://www.redpepperracing.com for ansers on that. (above and beond just yes)
Old Jan 24, 2008 | 01:14 PM
funkmaster's Avatar
ive got a used Chikara header for it...
$50 + shipping
Old Jan 24, 2008 | 03:52 PM
E-AT_me's Avatar
Default Re: (funkmaster)
HEY! that's my car!
Old Jan 24, 2008 | 04:28 PM
1g's Avatar
1g
like mine?
Old Jan 25, 2008 | 10:29 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
The only quad carb setups I've seen on these are people who have used motorcycle carbs fitted to modified intake manifolds. There are no off-the-shelf parts to do this with, but apparently it isn't too hard to chop the stock manifold and make it work. A few people on redpepper have done it.
The "hot" (read, expensive but more straightforward) setup is twin Weber sidedraft DCOE's. TWM used to make such a manifold but I believe it is out of production now. You can still find them used on ebay/redpepper classifieds/etc but there were probably other manufactures who made them as well.
Is your car carbed or is it a fuel injected Si? And header won't lean out a carbed engine, but *might* lean out an FI engine just a little bit. If your engine is otherwise stock then it shouldn't make enough difference to notice.
Old Jan 25, 2008 | 08:24 PM
Default Re: (E-AT_me)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-AT_me &raquo;</TD></TR><TR><TD CLASS="quote">HEY! that's my car!</TD></TR></TABLE>
.. my bad ive been meaning to get one of mine as soon as i could but ive been freakin busy,..
props on the build tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1g &raquo;</TD></TR><TR><TD CLASS="quote">like mine?
what motor is that? do you have any thread links to post for me with info for it it would be greatly appriciated
Old Jan 25, 2008 | 08:49 PM
jeffy's Avatar
Default Re: (86punishment)
that looks like an older prelude motor? and those are def. motorcycle carbs, old mikunis prob.
Old Jan 25, 2008 | 09:44 PM
SHUTTLE's Avatar
ZC brown top
Old Jan 25, 2008 | 10:42 PM
funkmaster's Avatar
not a ZC brown top, its a 86-87 USDM d16a1 out of a G1 Integra. ZC Brown top VC has HONDA in big letters.
Old Jan 26, 2008 | 05:39 AM
E-AT_me's Avatar
no biggie. i don't mind you using the pic..
Old Jan 27, 2008 | 04:46 AM
Default Re: (1g)
So,.. i can use a gen 1 integra motor to get the dohc setup but what about
mounts,
driveshafts,
and i still dont know the setup that works best
post links!!!
Old Jan 27, 2008 | 06:18 AM
E-AT_me's Avatar
buy a gen one integera doner car. you need the motor, mounts, transmission, axles, knuckles, brake rotors and discs..
or you can use 92+dx/cx brake calipers and discs.. (easier to find pads and generally a better setup due to the piston being the same size as stock Si brakes, unlike the larger teg piston.)
Old Jan 27, 2008 | 06:50 AM
Thats simple for me cuz im in with a couple salvage yards i can just take what i need ...
what about shifter linkage?
Old Jan 27, 2008 | 12:09 PM
E-AT_me's Avatar
i'm not sure. i've got a b16a in my car, so i don't have that problem. hehehee.
i believe that you use the teg ones. not 100% sure.check out redpepperracing.com for more answers..
Old Jan 29, 2008 | 05:51 AM
ok thanx man and i shouldn't put a headder on it as it is... ive gotten mixed answers
Old Jan 30, 2008 | 05:41 AM
Will a headder with stock exhaust lean the carb out too much?
ive heard yes and no
Old Jan 30, 2008 | 11:59 AM
redlynr's Avatar
My dual sidedraft Mikuni setup.
88HATCH(:
Jun 4, 2020 07:22 PM
98vtec
Jan 21, 2007 08:38 PM
spitfire600x
Jan 1, 2007 12:43 PM
Quad-Damage
Oct 10, 2005 01:26 PM
Slizammed_LS
Nov 28, 2003 10:44 AM
