Smell Gas on cold starts? Fuel Leak? Easy way to lower Psi?
Old Jan 24, 2008 | 06:44 AM
venomzz's Avatar
Default Smell Gas on cold starts? Fuel Leak? Easy way to lower Psi?
Is it normal to smell gas on cold starts? I think I have too much psi to my throttle body? still trying to solve this gas issue I am having.... could someone tell me the correct way to adjust or lower the fuel pressure/psi school me please....
Old Jan 24, 2008 | 08:04 AM
pdotjones's Avatar
Default Re: Smell Gas on cold starts? Fuel Leak? Easy way to lower Psi? (venomzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by venomzz &raquo;</TD></TR><TR><TD CLASS="quote"> could someone tell me the correct way to adjust or lower the fuel pressure/psi school me please....</TD></TR></TABLE>fuel pressure regulator... works well with a fuel pressure gauge, not totally neccessary but works well, sorta like burger and fries....
Old Jan 24, 2008 | 08:21 AM
hondapwr's Avatar
If your regulator is stock and you haven't messed with it, then your fuel pressure is probably fine. Check the fuel injector gaskets for leaks, and check your evaporative purge system.
Old Jan 24, 2008 | 09:47 AM
venomzz's Avatar
Default Re: Smell Gas on cold starts? Fuel Leak? Easy way to lower Psi? (hondapwr)
any recommendations on checking the evaporative purge system because its fumes I smell no visible leaks could my return line be clogged should I run some heat and injector cleaner through it....I pulled the injectors and put the seals back in and put the fuel rail back on that all seems cool....oh and there is a gauge on the regulator sits steady at 40
Old Jan 24, 2008 | 09:54 AM
Datphan's Avatar
fourty psi is a normal specs. since your car has ported fuel injections, it doesnt need cold start injectors (effin germans), it has to fire all four injectors at once to compansate for cold start, usually result in high gas fume. can you smell it when the car is at normal operating temperature?
Old Jan 24, 2008 | 10:03 AM
venomzz's Avatar
Default Re: Smell Gas on cold starts? Fuel Leak? Easy way to lower Psi? (Datphan)
not as much but I get really bad gas mileage with all the bolt ons and I can't understand how a 1.6 ltr engine would be gettin like 22-24 mpg but maybe Im just overreactin it just seems like if Im burnin that much gas I should have a lot more pull.
Old Jan 24, 2008 | 10:26 AM
Datphan's Avatar
you're running a bit rich.. replace air filter, check pcv/egr see if they're clogged.. any cel ?
Old Jan 24, 2008 | 06:19 PM
venomzz's Avatar
No CEL I bought this car the way it is and it runs spectacular closed loop when it is running rich and if it ran like that all the time I wouldnt be complaining but then when it runs open loop it drives like a completely stock honda and you would think my gas mileage would average out but that isnt the case. If its gonna get terrible gas mileage then I would prefer that it run the way it does closed loop all the time and I am worried if I put an ecu in it ....itll get even worse mileage but its cool appreciate everyones input
hbyrd8701
Aug 16, 2007 09:07 PM
bleedblue94
May 20, 2006 04:01 PM
Turbocivic94
Dec 24, 2005 09:12 AM
fitboy
Oct 16, 2004 02:12 AM
DR. ON POINT
Apr 4, 2002 02:07 PM
