this amp has GOT to power my subs...
Old Jan 23, 2008 | 04:26 PM
VTEC_PRODUCTION's Avatar
Default this amp has GOT to power my subs...
will this amp power my two kicker L7's?
i know that its rated at 1600 watts at 14.4 volts at 1 ohm in which i will run these subs. but will it run at 1600 watts while driving? i know i will be getting an alternator and thw right wire so im just wondering...also its parallel/parallel wiring for 4 ohm dual voice coil correct? thanks guys
http://cgi.ebay.com/HIFONICS-B...wItem
Old Jan 23, 2008 | 05:24 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: this amp has GOT to power my subs... (VTEC_PRODUCTION)
what model kickers?
Old Jan 23, 2008 | 05:44 PM
Default Re: this amp has GOT to power my subs... (wrx-killer-Sti-eater)
L7 didnt i type that? lol kickers 4 ohm DVC
Old Jan 23, 2008 | 08:43 PM
what I ment was size, the rms input for the subs. they come in 10 and 12 sizes.
Old Jan 24, 2008 | 05:14 AM
12 inches
Old Jan 24, 2008 | 01:02 PM
bump
Old Jan 25, 2008 | 04:29 AM
still have not gotten a solid answer...please help guys...
Old Jan 25, 2008 | 05:58 AM
fcm's Avatar
fcm
Old Fart
Kicker S12L7s are 750W subs with 2 of them you will need at least 1500W RMS to drive them properly.
Wired parallel/parallel for a 1 ohm load, the amp you have will drive them, however I would take the 1x1600W RMS into 1 ohm with a grain of salt, even at 14.5V, under normal driving your alt. will make about 13.5V and I have no idea what the amps output is at 13.5V.
The other issue is SQ, at 4 ohms, 1x550W it's not that bad a sounding amp, not great, but for sub bass it works, but at 1 ohm, [1x1600W] IMO, is sounds like crap.
IMO you are going to burn the VCs in the L7s within a few weeks if you "crank" the system, [push the amp to it's limit]. 94
Old Jan 25, 2008 | 07:46 AM
audioroach's Avatar
Default Re: this amp has GOT to power my subs... (fcm)
Actually according to my pals @ maxxsonics that amp will do its rated power @13.8volts. Its actually a very good choice for those subs.
Old Jan 25, 2008 | 04:29 PM
fcm's Avatar
fcm
Old Fart
Default Re: this amp has GOT to power my subs... (audioroach)
I guess it must be more efficient then other MOSFET amps to be able to make 1x1600W RMS with only two 80A fuses in it.
I do not trust specs that do not tell the whole story, nowhere on their site does it say at what voltage the 1600W is at, at what frequencies and what the THD is at the rated watts.
I wonder why they do not supply that info? 94
no_skillz
Audio / Security / Video
Oct 9, 2007 03:08 PM
Intrepidv614
Dec 13, 2005 05:02 PM
thegoods217
Mar 8, 2005 03:56 PM
pnthr30
13
Jun 15, 2004 07:05 PM
vtec-outlaw
Mar 2, 2002 11:19 PM
