GSR BUILD
Old Jan 23, 2008 | 11:37 AM
HondaTeKnology's Avatar
Default GSR BUILD
I read alot on this forum and found that alot of u guys bore and resleeve the block is that necessary? I don't tend to go to the drag races or be the fastest turbod gsr in the world. Also when do you upgrade the rods? I plan on upgrading pistons cams before I turbo it. Is it better to just keep it stock with a hondata upgrade, fuel pump and clutch instead? Any advice would be grade
Old Jan 23, 2008 | 11:45 AM
electron_si's Avatar
Default Re: GSR BUILD (HondaTeKnology)
post this up in the forced induction forum. Many of the guys there are experienced with that exact block and boosting
Old Jan 23, 2008 | 12:43 PM
Schister66's Avatar
Man U FTW
What are your power goals??
Stock blocks will handle up to 350whp reliably
Piston/rod builds will handle about 550whp
Sleeved blocks all depend on the setup....
Old Jan 23, 2008 | 02:44 PM
JKov240's Avatar
Default Re: (Schister66)
IMO, the weak point of Honda motors is the rods.
I decided to go ahead and "build" the bottom end of my GS-R when I had it out with SRP pistons and Eagle rods...it's insurance, and my car will be boosted in the near future, so I think it was a good investment, even if the rest of the motor is basically stock.
If you're planning on upgrading the pistons, then you might as well toss a set of rods in there while you're there.
Old Jan 23, 2008 | 02:45 PM
JDM_y0!'s Avatar
Default Re: (JKov240)
this is a good thread, i plan on doing this to m car when i get it =]
Old Jan 23, 2008 | 04:23 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 &raquo;</TD></TR><TR><TD CLASS="quote">IMO, the weak point of Honda motors is the rods. </TD></TR></TABLE>
That's only really true for D series. In B series engines, the ringlands are generally the first to go.
Old Jan 23, 2008 | 04:33 PM
JKov240's Avatar
I'm talking about in the case of abuse/mistake.
I've seen quite a few Honda motors at our shop that are "blown up" due to snapped rods...which were of course driver error (overrev).
But even then, I compared my stock GS-R rods to the forged Eagle ones...wowsas...the Eagle ones must been twice as thick/wide.
Old Jan 23, 2008 | 04:35 PM
H.A.R.T B18C1EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
That's only really true for D series. In B series engines, the ringlands are generally the first to go. </TD></TR></TABLE>
and H series
Old Jan 24, 2008 | 01:41 AM
Default Re: (H.A.R.T B18C1EG6)
thanks 4 the advice.
Old Jan 24, 2008 | 01:44 AM
350 or 400 little by little to acheive this goal but at the same time make it reliable. I was thinkin that u needed to resleeve the block in order to go higher than 350.
killerB16A
Sep 6, 2009 05:51 PM
BoOstedN1ck
Aug 8, 2009 05:22 AM
digital sol
Sep 28, 2005 02:30 AM
JdmEkb18
Mar 26, 2005 08:41 AM
ScottEK
Oct 8, 2003 07:52 AM
