GSR BUILD
GSR BUILD
I read alot on this forum and found that alot of u guys bore and resleeve the block is that necessary? I don't tend to go to the drag races or be the fastest turbod gsr in the world. Also when do you upgrade the rods? I plan on upgrading pistons cams before I turbo it. Is it better to just keep it stock with a hondata upgrade, fuel pump and clutch instead? Any advice would be grade
Man U FTW
What are your power goals??
Stock blocks will handle up to 350whp reliably
Piston/rod builds will handle about 550whp
Sleeved blocks all depend on the setup....
Re: (Schister66)
IMO, the weak point of Honda motors is the rods.
I decided to go ahead and "build" the bottom end of my GS-R when I had it out with SRP pistons and Eagle rods...it's insurance, and my car will be boosted in the near future, so I think it was a good investment, even if the rest of the motor is basically stock.
If you're planning on upgrading the pistons, then you might as well toss a set of rods in there while you're there.
Man U FTW
Re: (JKov240)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JKov240 »</TD></TR><TR><TD CLASS="quote">IMO, the weak point of Honda motors is the rods. </TD></TR></TABLE>
That's only really true for D series. In B series engines, the ringlands are generally the first to go.
Re: (Schister66)
I'm talking about in the case of abuse/mistake.
I've seen quite a few Honda motors at our shop that are "blown up" due to snapped rods...which were of course driver error (overrev).
But even then, I compared my stock GS-R rods to the forged Eagle ones...wowsas...the Eagle ones must been twice as thick/wide.
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">
That's only really true for D series. In B series engines, the ringlands are generally the first to go. </TD></TR></TABLE>
and H series
and H series
Re: (JKov240)
350 or 400 little by little to acheive this goal but at the same time make it reliable. I was thinkin that u needed to resleeve the block in order to go higher than 350.
