Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow Help
Old Jan 21, 2008 | 10:39 PM
99_turboteg's Avatar
Default Koni Yellow Help
i have koni yellows with skunk 2 coil overs on them and i havent adjusted them in about a year and i went to do it last night because i am going to lower it more but... the top ring seems to be severly stuck to the actual spindle
one of my friends said maybe decompressing the shock would work so we left it hanging in the air overnight with the wheel off on jack stands
still no luck
sooo now i am asking you... what do you think the issue is?
Old Jan 22, 2008 | 12:22 AM
Default Re: Koni Yellow Help (99_turboteg)
Old Jan 22, 2008 | 04:23 AM
johnlear's Avatar
Banned
What do you mean by "top ring", and "actual spindle"?
Old Jan 22, 2008 | 05:13 AM
nater_1's Avatar
hmmm.. is the adjuster ring rusted to the sleeve? If so, I would spray it with pb blaster several times a day for several days, and then try it...
Old Jan 22, 2008 | 10:27 AM
Default Re: (nater_1)
could be a possibility
Old Jan 22, 2008 | 11:28 AM
98vsmhatch's Avatar
Your thread topic says Koni Yellow Help. You stated you havent adjusted it in a year after you stated that you have them mated w/ skunk 2 coilovers.
what confuses me is the adjustment part, are you adjusting the rebound dampening on the Koni Yellows(i would assume so since thats what the topic states) OR are you adjusting the ride height on the skunk 2's?
The rest of you post doesn't quite make sense as per what johnlear is asking.
clear it up a bit so we can understand whats going on, perhaps take some pictures and post them?
Old Jan 22, 2008 | 02:09 PM
Default Re: (98vsmhatch)
pics tonight...
Old Jan 22, 2008 | 02:35 PM
PuroMotor's Avatar
WD40 the adjuster....... if not, it sounds like it needs a rebuild.
mtny
Suspension & Brakes
Sep 25, 2006 01:36 PM
Undercover_Skank
Aug 30, 2004 12:55 PM
loid
Jul 12, 2004 05:20 PM
Dave421
Jul 1, 2003 10:34 AM
