Help!!!Clutch master cylinder!!!
Last week the clutch was all the way on the floor...so i checked the master cylinder and what do you know...there is no fluid what so ever...so i put some brake fluid and bled the brakes...so, so far so good...then today it was all the way to the floor again...so i check the maskter cylinder again and no fluid...so i redid what i did last week... and this time i checked for leaks...NO LEAKS...or i cant find it...what problems can i have...or what should i check??? HELP PLEASE!!!
fill it with fluid, drive it a few miles, then pop the hood and start at the clutch master cylinder, follow the line till you get to the clutch slave on the transmission.
did you find the leak?
you'll probally need replace clutch master cylinder and clutch slave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juniestyle »</TD></TR><TR><TD CLASS="quote">so i check the maskter cylinder again and no fluid...so i redid what i did last week... and this time i checked for leaks...NO LEAKS...or i cant find it...what problems can i have...or what should i check??? HELP PLEASE!!!
it's gotta be going somewhere. check in front of the tranny at the slave cylinder.
</TD></TR></TABLE>it's gotta be going somewhere. check in front of the tranny at the slave cylinder.
JDMswagSerf
Dec 10, 2013 09:47 PM
