b16a obd1 oil pressure and temp
Old Jan 21, 2008 | 07:06 PM
sohctodohc's Avatar
Default b16a obd1 oil pressure and temp
hey searched for some results on this and couldnt find a whole lot.
what is the normal temp your oil should be after your car is warmed up.
and would you rather see the oil temp in the oil pan(drain plug as sending unit) or flowing oil temp(oil block adapter)?
and what is the average pressure WOT? idling? and cruising???
by the way this is a stock obd1 b16a
ok so got the gauges in the center console and at cold idle, idle then wot it goes as follows:
80psi
22psi
80psi
does that sound right?
thanks for the help
Old Jan 22, 2008 | 10:53 AM
2001B18C1GS-R's Avatar
i not sure about 22psi mine at idle read 80 cold
Old Jan 22, 2008 | 04:13 PM
sohctodohc's Avatar
Default Re: (2001B18C1GS-R)
sorry thats 22psi at operating temp. and i have a block adapter so it reads a little extra cuz it reads right before being filtered.
and cold idle is right at 80psi
TeamSeanFTW
Mar 15, 2011 06:41 PM
sohctodohc
Jan 21, 2008 06:52 PM
soontobeboost
Jan 6, 2007 06:22 AM
TurboCX
Aug 3, 2003 06:33 PM
Driven
Jan 4, 2002 01:35 PM
