jdm front conversion.
thinking about gettin a teg and doing jdm front end now i have read up on the rad support removal and install and most people take it all apart and re weld it on.. i saw on instance where they usdm support had a T shapped cut out and another T shape from the jdm suport was welded in to the usdm suport.. sry for rambaling on but does any one have more info on this way of doing it.. all help is apreciated..
yeah i know that all i have to change is the top part for the head lights but does any one know the mesurments i dont wanna weld it in and it be sideways.. u knows..
it really not done by measurements mosty just drill the spot welds and align to that or use pressure pliers to hold it then install the front alight it and then weld....that what i did
wrd so u say use the pressure plyers then put the fenders hood lights etc on then if it lines up then just weld it up. sounds easy enough.
