jdm type r conversion
Old Dec 18, 2005 | 02:57 AM
92civic_si's Avatar
Default jdm type r conversion
i'm doing a jdm type r conversion to my 95 integra..i have everything but the raditor support..i heard that you can still use the DC oem raditor support for the conversion..is that true? or do you have to get a jdm type r raditor support!! thanks
Old Dec 18, 2005 | 03:00 AM
92civic_si's Avatar
Default Re: jdm type r conversion (92civic_si)
bump
Old Dec 18, 2005 | 04:51 AM
Backk InTheDA's Avatar
I hate everything
Im not sure, but I think you need the JDM radiator support.
Try a search if no one else posts, I know this has been covered a few times.
Old Dec 18, 2005 | 05:33 AM
Team Underground Teg's Avatar
Default Re: jdm type r conversion (BuilttB18C5)
I am almost 100% sure that you have to use the JDM rad support. I dont know how you could use the USDM support...
Old Dec 18, 2005 | 10:16 AM
Chriz's Avatar
Default Re: jdm type r conversion (Team Underground Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team Underground Teg &raquo;</TD></TR><TR><TD CLASS="quote">I am almost 100% sure that you have to use the JDM rad support. I dont know how you could use the USDM support...</TD></TR></TABLE>
i agree....100% sure you need the jdm support....i dont think you can install it with usdm support....you can install it with out welding i saw that thread....
https://honda-tech.com/zerothread?id=1346217
Old Dec 18, 2005 | 10:29 AM
SYTFU Tommy.'s Avatar
Default Re: jdm type r conversion (Chriz)
u can still use the usdm raditor support with the jdm raditor "t"
Old Dec 18, 2005 | 11:42 AM
MugenDC4's Avatar
i read somewhere that you probably could use the USDM radiator support but not 100% I wouldn't recommend it though. Get the job done right using the JDM radiator support because not worth risking trying to save $200-300
Old Dec 18, 2005 | 11:56 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: jdm type r conversion (MugenDC4)
You cannot use the stock USDM radiator support for a JDM conversion.
You must use the JDM radiator support, if not the full support then at least the "T" section (the part that the holds the headlights and hood latch).
Old Dec 18, 2005 | 03:57 PM
teggy182's Avatar
Default Re: jdm type r conversion (carma_626)
just get the jdm support
Old Dec 18, 2005 | 04:00 PM
5 Speed AP2's Avatar
Default Re: jdm type r conversion (teggy182)
Without modifying the stock radiator support it CANT be done.
I've even seen someone modify an early 90's accord rad core and made it work.
But going this way will jus give you more work to do.
Get the oem jdm one and save yourself the extra headache.
Old Dec 18, 2005 | 04:20 PM
B2FiNiTY's Avatar
Default Re: jdm type r conversion (5 Speed DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Without modifying the stock radiator support it CANT be done.
Get the oem jdm one and save yourself the extra headache.</TD></TR></TABLE>
Exactly. Just get the JDM radiator support.
trepteg
Oct 4, 2007 11:36 AM
whiteknightef
Aug 21, 2006 11:54 PM
djlavb20
Aug 8, 2005 09:04 AM
B00STeD
Dec 29, 2002 06:20 PM
uber_nihilist
Apr 23, 2002 07:22 PM
