boost control
Old Jul 1, 2002 | 02:23 PM
CiViC SiR's Avatar
Default boost control
how can increas the boost from 5 to 7.5 Psi without boost controler?
Old Jul 1, 2002 | 04:46 PM
.nate's Avatar
Default Re: boost control (CiViC SiR)
You can do one of two things...
First off you can change out the spring in your wastegate to a 7lb spring.
Second off... Even though you said that you didnt want a boost controller, I am assuming that you mean you dont want to BUY one. If you dont want to buy one, but still wouldnt mind having one, you should check out the following links dealing with making a homemade boost controller. You can build one super cheap
http://www.well.com/user/mosk/boost.htm
http://www.pacarsearch.com/stealth/boostcontroller.htm
http://home.att.net/~jason510/ManualController.htm
You can even get a little more complex and rock something like this:
http://pages.cthome.net/gus/mike.html
--ALSO--
Check out http://www.fwdmopar.com/sites/dennis...trolbible.html... it has a boatload of boost control- related links
Good luck, and dont blow up your ****
Atlas
Mar 15, 2004 06:33 AM
MachAF
Jun 27, 2003 05:14 PM
PUREVIL
Jun 23, 2003 06:23 PM
echo999
Oct 3, 2002 07:41 PM
accordfreak
Dec 25, 2001 12:20 AM
