Thickest HeadGasket available???
Old Jan 21, 2008 | 08:20 AM
DA_JDM's Avatar
Default Thickest HeadGasket available???
Hi guys,
I have bought some wiseco B18C1 pistons to put into my B18C5 block...the CR specs are 12:5 to 13:2...i really dont wanna be into the 13 because its gonna be a street motor and im not planning on runing on race fuel...so basicly i wanna stay into the 12:5-12:6 CR to be able to have it tuned perfectly on 94octane!!!
Is cometic making a thick gasket??? I was going to go with an OEM but im going 82mm so i think the OEM one wont be a good choice...
Please help me out on this guys
Old Jan 21, 2008 | 09:19 AM
( o )( o )'s Avatar
Default Re: Thickest HeadGasket available??? (DA_JDM)
I have used gaskets that were .062" and .074" thick. Call Cometic or SCE Gaskets.
Old Jan 21, 2008 | 09:46 AM
Chris Tune's Avatar
kidna hard to believe a 13:1 comp with some off the shelve pistons on a gsr @ 82mm without some milling....
8.25cc's usually net very high 11's low 12's...
Old Jan 21, 2008 | 10:12 AM
DA_JDM's Avatar
Default Re: Thickest HeadGasket available??? (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune &raquo;</TD></TR><TR><TD CLASS="quote">kidna hard to believe a 13:1 comp with some off the shelve pistons on a gsr @ 82mm without some milling....
8.25cc's usually net very high 11's low 12's... </TD></TR></TABLE>
Wiseco K593M82!!! between 12:5 & 13:2 as stated on their website!!!
Last year i was runing their 12:6 81.5mm one into my ITR block...with a spoon 2layer HG and an unmilled head i was at around 12:1-12:2 of CR!!!
My head was destroyed so i have no choice to milled it in the reconstruction process...i just wanna try to figure out how to get an average 12:5 CR with those pistons and be safe on 94octane gaz
Old Jan 22, 2008 | 04:45 AM
DA_JDM's Avatar
Need help guys
Old Jan 22, 2008 | 06:07 AM
Chris Tune's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">
My head was destroyed so i have no choice to milled it in the reconstruction process...i just wanna try to figure out how to get an average 12:5 CR with those pistons and be safe on 94octane gaz </TD></TR></TABLE>
i know the part number and the "supposed" comp ratios... measure and maybe you can really use a calculator to REALLY know your ballpark.
Old Jan 22, 2008 | 10:50 AM
2001B18C1GS-R's Avatar
whats happen to the 81.5mm bore build very silimiar to my build and comp numbers thats y im asking
Old Jan 22, 2008 | 11:45 AM
DA_JDM's Avatar
Default Re: (2001B18C1GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001B18C1GS-R &raquo;</TD></TR><TR><TD CLASS="quote">whats happen to the 81.5mm bore build very silimiar to my build and comp numbers thats y im asking</TD></TR></TABLE>
Are you talking about my built of last year???
If yes ive dropped some valves back in august so im going 82mm now with some little other things to help me broke the 225whp mark
Old Jan 23, 2008 | 05:08 AM
DA_JDM's Avatar
i know the part number and the "supposed" comp ratios... measure and maybe you can really use a calculator to REALLY know your ballpark. </TD></TR></TABLE>
Thanks
c5stunna
19
Jun 17, 2008 08:18 PM
boostincoupe
Aug 30, 2006 10:04 AM
B00ST2nR
Sep 22, 2004 02:50 PM
adeihl
Aug 18, 2004 09:17 AM
rusted_eyes
17
Jul 13, 2004 05:28 PM
