Ninjas: Options for a 76mm (1mm over) headgasket?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I'm thinking about trying the Vitara pistons in the .040" (1mm) oversized model on a spare Y8 block I'd like to do a stock sleeve build on. I'd like to see what these pistons can really do (300whp+).
My question is: what are my headgasket options? Cometic? OEM, and bore it?
Let me know, thanks in advance
Re: Ninjas: Options for a 76mm (1mm over) headgasket? (boostincoupe)
bump!
Also, for those of you running 75.5mm pistons on your built SOHC, what HG are you running? OEM, bored out?
Re: Ninjas: Options for a 76mm (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Also, for those of you running 75.5mm pistons on your built SOHC, what HG are you running? OEM, bored out?</TD></TR></TABLE>
With my 75.5mm bore I run the stock OEM gasket, not bored out. For .5mm over it's not necessary to bore out the stock gasket at all.
Re: Ninjas: Options for a 76mm (Justin Jones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones »</TD></TR><TR><TD CLASS="quote">Cometic, 75.5mm HP gasket. .030 thickness.
Viatra pistons? *sigh* please don't. worst quench area evar!1!1</TD></TR></TABLE>
actually i just searched for a pic and they're not THAT bad. for some reason i remember them just having a really basic dish with a thin rim around the edge of the crown...
I'm actually looking at 75.5mm Nippon "turbo" pistons, the ones that have a full floating pin design so they can work with Eagle/Tuner Toys rods.
Don't hate. it's Operation: 4 Cheap.
Re: Ninjas: Options for a 76mm (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
With my 75.5mm bore I run the stock OEM gasket, not bored out. For .5mm over it's not necessary to bore out the stock gasket at all.</TD></TR></TABLE>
Nobody bores a head gasket for a .5mm increase in diameter. Remember, that equates to a .25mm increase in radius - you won't even be able to see that when you line up the gasket with the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">I'm thinking about trying the Vitara pistons in the .040" (1mm) oversized model on a spare Y8 block I'd like to do a stock sleeve build on. I'd like to see what these pistons can really do (300whp+).
Let me know, thanks in advance </TD></TR></TABLE>looking for a headgasket for my 76mm sohc?
jay-d-em
16
04-18-2013 03:45 PM
