Suspension & Brakes Theory, alignment, spring rates....
Signs of a bent rear LCA
Old Jan 20, 2008 | 11:26 PM
brototoy's Avatar
Default Signs of a bent rear LCA
what are the signs? is the camber way off?
thanks!
Old Jan 21, 2008 | 04:38 AM
meb58's Avatar
Default Re: Signs of a bent rear LCA (brototoy)
Either the top of the tire is aggressively angled toward the center of the car or the top of the tire is aggressively angle opposite the car's centerline. More thanlikely, a bushing is worn...unless the car is super low?
Old Jan 21, 2008 | 08:54 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brototoy &raquo;</TD></TR><TR><TD CLASS="quote">what are the signs? is the camber way off?
thanks!</TD></TR></TABLE>
What car?
Does it look bent to you?
Old Jan 21, 2008 | 04:22 PM
4XmattX2_0X's Avatar
Default Re: Signs of a bent rear LCA (Targa250R)
jack your car up and see if its bent or not
Old Jan 21, 2008 | 09:40 PM
brototoy's Avatar
ek sedan. its just that the driver's side camber is a lot more negative than the opposite side
Old Jan 22, 2008 | 03:20 AM
Targa250R's Avatar
be professional
Default Re: (brototoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brototoy &raquo;</TD></TR><TR><TD CLASS="quote">ek sedan. its just that the driver's side camber is a lot more negative than the opposite side</TD></TR></TABLE>
There could be a number of problems.
If a '96-00 Civic LCA is bent a significant amount, it's usually pretty obvious.
What are your current alignment specs back there?
Old Jan 22, 2008 | 03:39 AM
dyingwish's Avatar
Default Re: (Targa250R)
Did the car suffer some sort of impact? LCA's don't just bend on thier own. Did you just do a susp install of some sort? IF so I'd bet something (spring probably) isn't seated correctly.
Old Jan 22, 2008 | 05:55 PM
.PLUMMM's Avatar
Default Re: (dyingwish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyingwish &raquo;</TD></TR><TR><TD CLASS="quote">Did the car suffer some sort of impact? LCA's don't just bend on thier own. Did you just do a susp install of some sort? IF so I'd bet something (spring probably) isn't seated correctly.</TD></TR></TABLE>
x2. It would be pretty hard to just bend a lower control arm from simply lowering a car. If you installed any sort of springs, check how your springs are seated and that everything is bolted up correctly.
Old Jan 23, 2008 | 03:42 AM
brototoy's Avatar
if the LCA's bushing is busted, what would be its sign?
Old Jan 23, 2008 | 04:07 AM
dyingwish's Avatar
Well the LCA itself has three bushings (inner, shock mount, and outer)
They don't break, per se, they just crack and get brittle over time. Just inspect them closely and check for cracks. Might as well check the traling arm bushing as well, those will normally crack the whole way through.
Old Jan 24, 2008 | 11:04 AM
brototoy's Avatar
ok thanks man!
redDAinteg
Jun 6, 2007 03:52 AM
ekim952522000
12
Jul 15, 2006 12:49 PM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
B HATCH
132
Jul 23, 2005 03:16 PM
Wazup
19
Mar 11, 2004 06:18 AM
