need help on turbo charging a b17a1
Old Jan 20, 2008 | 09:59 PM
ek986's Avatar
Default need help on turbo charging a b17a1
im going to turbo my b17a1....but don't know wat size i will need for the head gasket....i'm looking a going about 10-14 psi on the motor....no bult, just puting a thicker head gasket on....and can any one tell me wat size head gasket a 2mm is and a 3mm.....also do i need aftermaket cam gear or i can just use my stock one to do the timming on the motor....
Old Jan 21, 2008 | 02:04 AM
Pat_S's Avatar
Default Re: need help on turbo charging a b17a1 (ek986)
Seeing you have only 2 posts, I'm assuming you haven't used the search button yet?
Old Jan 21, 2008 | 04:00 AM
jhammond_82's Avatar
Reject Papi
Default Re: need help on turbo charging a b17a1 (Pat_S)
i'm no genious but i would say that a 3mm is thicker than a 2mm. https://honda-tech.com/zerosearch use it.
Old Jan 21, 2008 | 05:34 AM
karma28217's Avatar
why would you turbo the rarest honda motor, sell it to me and ill give u my b18a1 to turbo
: D lol jk
Old Jan 21, 2008 | 05:47 AM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek986 &raquo;</TD></TR><TR><TD CLASS="quote">im going to turbo my b17a1....but don't know wat size i will need for the head gasket....i'm looking a going about 10-14 psi on the motor....no bult, just puting a thicker head gasket on....and can any one tell me wat size head gasket a 2mm is and a 3mm.....also do i need aftermaket cam gear or i can just use my stock one to do the timming on the motor....</TD></TR></TABLE>
1. it's "what" not "wat", and i'll give you the benfit of the doubt on the other misspelled words.
2. you are obviously uneducated on this topic, and others...if i were you i would head over to the forced induction forum and educate yourself about the basics.....
Old Jan 21, 2008 | 07:22 AM
1dumbscreenname's Avatar
Default Re: need help on turbo charging a b17a1 (GRAF-FITI)
belongs in the FI forum.
Old Jan 21, 2008 | 08:15 AM
ek986's Avatar
look...if i know what i was going to do... then i wouldn't be asking any of the smart *** people in here.... And it just a small question....not a big one.... so if all you smart *** don't want to help, then don't even say anything.
Old Jan 21, 2008 | 08:24 AM
Reject Papi
Default Re: (ek986)
https://honda-tech.com/zeroforum/16 that should get you started. you have to know what your goals are. daily driver, track only, and what kind of horsepower you want to put down.
410ruga
Jul 12, 2014 03:52 PM
ben222
Aug 29, 2007 06:11 PM
mcgee*
Feb 14, 2006 03:26 PM
TypeSLO
Jan 31, 2006 06:30 PM
razz9818
Jul 29, 2004 03:40 PM
