Just installed a new clutch, car only goes into reverse.
Old Jan 20, 2008 | 09:11 PM
DC5Danny's Avatar
Streets closed Pizzagate boy
Default Just installed a new clutch, car only goes into reverse.
Can anyone explain why this would happen?
Old Jan 20, 2008 | 10:02 PM
all-mtr-teg's Avatar
Default Re: Just installed a new clutch, car only goes into reverse. (DC4Dan)
Improper installation, bad clutch, clutch fork not installed correctly, low tranny fluid? Will it get into gear when the car is off?
Old Jan 20, 2008 | 10:17 PM
DC5Danny's Avatar
Default Re: Just installed a new clutch, car only goes into reverse. (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">Improper installation, bad clutch, clutch fork not installed correctly, low tranny fluid? Will it get into gear when the car is off?</TD></TR></TABLE>
I think the tranny fluid may have something to do with it. We didnt drain it prior to dropping the trans, then imo all 2.5 quarts came out. We only put back 1.5 because we weren't 100% sure all of the fluid came out. Should we add more fluid and see what happens?
Old Jan 20, 2008 | 10:31 PM
Check the fluid level and make sure its up to the correct level. Is it smooth going into reverse and unable to get into any other gear? Also, does the tranny shift into gear when the car is off?
Old Jan 20, 2008 | 10:32 PM
luckymachine7's Avatar
it not the fluid because you can still shift it into gear even without mtl. Did you put the shift linkage in right?
Old Jan 21, 2008 | 03:03 AM
skata89's Avatar
I would refill the tranny and your shift linkage is probably too tight.
Old Jan 21, 2008 | 06:39 AM
DC5Danny's Avatar
bump
Old Jan 21, 2008 | 08:36 AM
CRJenkins13's Avatar
Your shift linkage is loose.
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
niceprelude
Nov 7, 2008 10:22 AM
BlackLudeSR
Jun 21, 2007 01:50 PM
andrewasf77
Jun 19, 2003 07:32 PM
machine4321
Jun 1, 2003 10:41 PM
