Cigarette lighter dont work
Old Jan 20, 2008 | 04:06 PM
jdmcd5a's Avatar
Default Cigarette lighter dont work
Does n e body know what it can be?let me know plz bc trying to connect a radar detector but doesnt work bc the lighter co0nnection is not working thanks!!!
Old Jan 20, 2008 | 04:23 PM
HondaTechAV6's Avatar
Default Re: Cigarette lighter dont work (jdmcd5a)
most likely it's a blown fuse for the accessory power socket.
Old Jan 20, 2008 | 04:24 PM
TheMuffinMan's Avatar
He knows where you live!
Check the fuse for it, if that's fine and the plugs are fine on the back
Buying a new harness would be the simple solution.
It comes with a new plug and the wiring
Old Jan 20, 2008 | 06:48 PM
96blackaccordv6's Avatar
Default Re: (TheMuffinMan)
I had this problem in my car. What i'd do (besides checking the fuses) is checking to see how tight the connection is on the back of the cig. lighter. If you can stick your finger in the lighter and turn it or even move it around then it isn't tight enough. It being unscrewed just a little bit can not give you sufficiant power to light anything.
Let me know what you find out. I might be able to guide you through the procedures on removing the panals to get to it--if that's the case.
Old Jan 20, 2008 | 08:11 PM
The-Kid's Avatar
Default Re: (96blackaccordv6)
Was the car used when you bought it and it came with an aftermarket radio?
I know when I was installing mine, the radiofuse would break because of the cig lighter being connected. (They share the same fuse) So I just unplugged the cig lighter connector behind the panel.
So does your car come with aftermarket radio?
Old Jan 20, 2008 | 09:27 PM
jdmcd5a's Avatar
Default Re: (The-Kid)
yeah it came wit an after market radio
Old Jan 20, 2008 | 09:59 PM
The-Kid's Avatar
Default Re: (jdmcd5a)
Yea I would suggest opening it up to see if the cig lighter is connected... Does the cig light up when you turn on parking lights and stuff? It's suppose to have like a green effect around the white border.
Old Jan 21, 2008 | 03:37 PM
jdmcd5a's Avatar
yeah the green light turns on
Old Jan 21, 2008 | 04:13 PM
hondadude's Avatar
If you open the hood or drivers door there will be a sticker that says WHAT YEAR accord you have.
Some years have a thermal pop off in a plastic case on the back of the lighter socket.
Because people hold the lighter in to get it white hot so they can drop their roaches on it for good nose hits, and that blows the pop off.
You can resolder the pop off tab.
FWIW the trim light is a different circuit
Joshb152
Apr 14, 2015 04:48 PM
nerd28
Jul 16, 2006 05:36 PM
asianalbutt
Sep 28, 2005 04:21 PM
JDM-FREAK
Oct 6, 2002 10:11 PM
