how can this suspension be raised?
Old Jan 20, 2008 | 09:15 AM
jetblack's Avatar
Default how can this suspension be raised?
Hoping somone can point out what i'm missing here.
I've got Koni yellow shocks and Tanabe springs all round. The suspension sits too low so i'm going to raise it up, but this morning, whilst i had the wheels off i noticed that the front already appears to be on the highest setting.
Thing is the car is very low (wheel tucked right up in the arches) so surely there must be more adjustment upwards?
The only thing i can think off is to turn the 'cup' the other way round but it doesn't look like it can seat the other way around.
Any advice appreciated.
Old Jan 20, 2008 | 09:20 AM
slow_cx's Avatar
Buy some coilovers. Or stay slammed.
Old Jan 20, 2008 | 09:40 AM
Dann6968's Avatar
Default Re: how can this suspension be raised? (jetblack)
I dont know why you would be so low on that setting. Does it look like you springs have been cut?
Sorry, I'm not sure if you can flip the perch around.
Old Jan 20, 2008 | 09:45 AM
Syndacate's Avatar
Default Re: how can this suspension be raised? (Dann6968)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dann6968 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know why you would be so low on that setting. Does it look like you springs have been cut?
Sorry, I'm not sure if you can flip the perch around.</TD></TR></TABLE>
I don't believe you can flip it around, though for the highest setting to be slammed - they gotta be cut or something .
Old Jan 20, 2008 | 10:28 AM
jetblack's Avatar
Nope, they are not cut, i bought everything new about 2 years ago.
Think i'll get some koni adjustable threaded perches and raise it up that way (then i can corner weight as well)
Old Jan 20, 2008 | 10:44 AM
Eran's Avatar
HT White Ops
The perches aren't really for height adjustment. They're more for setting preload.
Old Jan 20, 2008 | 10:45 AM
instrument's Avatar
only thing i can think is that your springs weren't made for your car.
springs made for a EF will fit an EG civic, but will be far shorter, possibility?
either way like you said you'll need coil overs...so good luck
Old Jan 20, 2008 | 11:48 AM
jetblack's Avatar
Default Re: (instrument)
Defo the right parts for the car, checked the part numbers.
Maybe they've just sagged.
I'm enquiring with king motorsport about some adjustable threaded perches. I'll see what they come back with.
Old Jan 20, 2008 | 12:05 PM
VTEC_PRODUCTION's Avatar
Default Re: (jetblack)
you can just get some cheap sleeves off of ebay or me and you can make it adjustable
BakPil
Honda Civic (2001 - 2005)
Aug 16, 2008 03:44 PM
jorkee
Mar 16, 2008 10:14 PM
kevo1586
Nov 21, 2007 07:40 AM
sleeperLS
Aug 25, 2005 09:20 AM
teknikEG6
Mar 22, 2004 08:25 PM
