need help fuel presure gauge reading high
Old Jan 20, 2008 | 01:25 AM
6speed-ferio's Avatar
Default need help fuel presure gauge reading high
i got a 2000 civic si coupe wth basic bolt on's,header.intake,exhaust...but today i installed a AEM fuel rail and a b&m gauge (did not upgrade the fuel pressure regulator yet)for some odd reason i started up the car and the gauge read 80psi is this bad and is this why car smokes (black/grey color) and smells like gas? so after i was trippin out so i thought my gauge was broken so i bought a new one and it still read 80psi, so then after i thought my injectors were bad so i installed an extra set that i had and still yet it read 80psi ,so after that im still trippin out even more so what i did next was change the stock regulator to another stock regulator and still read 80psi...need your guys help in fixing this problem thanks.........
Old Jan 20, 2008 | 02:07 PM
Mikey3000's Avatar
Default Re: need help fuel presure gauge reading high (6speed-ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6speed-ferio &raquo;</TD></TR><TR><TD CLASS="quote">is this bad and is this why car smokes (black/grey color) and smells like gas? </TD></TR></TABLE>
yep. can u show pics of the fuel rail and how u set up the gauge?
Old Jan 24, 2008 | 11:44 AM
Default Re: need help fuel presure gauge reading high (Mikey3000)
ok yesterday i installed an aem fuel presure regulator tried to adjust the pressure and it still stuck at 80 psi what hell could be wrong?need help
Old Jan 25, 2008 | 06:56 PM
boostedh22lude1's Avatar
injectors have nothing to do with fuel press. omly pump and regulator, the regulator should only be like 41-47 psi without vacuum with vacuum about 32-38, so there is no reason it is at 80 unless the regulator is after market and not set right or the regulator is bad and usally when there bad and ive never seen a bad honda reg., they dont have enough pressure to start the car.
Old Jan 26, 2008 | 08:33 AM
King V's Avatar
Default Re: need help fuel presure gauge reading high (boostedh22lude1)
Check your return lines back to the tank. Sounds like the fuel thats supposed to go back thru to the tank is getting dumped into the motor. And whatever happens, expect to either remove or replace your converter, cause you just poisoned it.
Old Jan 31, 2008 | 09:39 PM
Default Re: need help fuel presure gauge reading high (King V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King V &raquo;</TD></TR><TR><TD CLASS="quote">Check your return lines back to the tank. Sounds like the fuel thats supposed to go back thru to the tank is getting dumped into the motor. And whatever happens, expect to either remove or replace your converter, cause you just poisoned it.</TD></TR></TABLE> im going to check my return lines tomorrow even one of my homies thought the same as you,he thinks the return line is clogged also,so what im gonna do is check the lines underneath the car and see if a line is pinched if its all good im going use a air compressor and blow air through the return line.btw about my converter im actually running straight pipe from headers to my apexi world sport exhaust...but thanks for your opinion
Old Feb 1, 2008 | 09:54 PM
blinx9900's Avatar
buy a new liquid filled gauge, mount it on the rail if its not already there and then post the difference, those gauges are CRAP!!
6speed-ferio
Jan 24, 2008 02:35 PM
full Circling
Jul 13, 2005 01:31 PM
chrisb
May 9, 2005 07:06 PM
cvc323
Oct 27, 2004 09:01 AM
Blanket Jackson
Aug 1, 2003 08:29 AM
