obd1 b16 no rev limiter?
Old Jan 19, 2008 | 10:10 PM
jasony0630's Avatar
Default obd1 b16 no rev limiter?
my car has a b16a3 running on a stock p30 and i missed 4th today and it revved past 9k, it was about 9500 rpm and it didnt rev limit....is this normal?
Old Jan 19, 2008 | 10:17 PM
994door's Avatar
Default Re: obd1 b16 no rev limiter? (jasony0630)
No missing a gear isn't normal. j/k. No it's not normal. Maybe it's chipped. Is a p30 OBD1 or OBD2? Cause if it's OBD1 it could be chipped.
Old Jan 19, 2008 | 10:18 PM
jasony0630's Avatar
no its not chipped, ive opened it up....so idk wtf is wrong...maybe thats just saying i should miss gears lol
Old Jan 20, 2008 | 06:58 AM
afstvx's Avatar
did you miss 4th or go back to 2nd. if you went back to second the car will rev past rev limiter as long as the car is not accelerating it will rev past the limiter. like if you go from 5th to second and just let the clucth out it will rev hella high. a lot of people would do the this when the rsx's first came out they would miss 4th to 5th becasue the transmissions are so close. but if you just didnt get the car into 4th ( or any other gear ) and it just reved it should have hit the rev limitter.
Old Jan 20, 2008 | 11:49 AM
.PLUMMM's Avatar
Is it still running fine? No stock b16 should rev. to 9500 rpm. If everything feels fine, then you are lucky. I wouldn't recomend doing that again. Next time your valves might not be as forgiving lol
Old Jan 20, 2008 | 11:54 AM
Hardedge's Avatar
Are you saying you miss-shifted into a lower gear? There's nothing the ECU can do about that, it's called a mechanical over-rev. You're using the gearing and the forward speed of the vehicle to rev the engine.
Old Jan 20, 2008 | 11:57 AM
jasony0630's Avatar
oh...then thats probably what i did, i think i did miss fourth and put it in second...it scared the **** outta me
but thank god the b16 is still fine..i love that engine
Old Jan 20, 2008 | 03:10 PM
poorhonda's Avatar
Default Re: obd1 b16 no rev limiter? (994door)
how bad is it to be shifting my gsr all the time 8100 rpms
Old Jan 20, 2008 | 03:14 PM
Hardedge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorhonda &raquo;</TD></TR><TR><TD CLASS="quote">how bad is it to be shifting my gsr all the time 8100 rpms </TD></TR></TABLE>
It's just accelerated wear, that's all. Unless you miss-shift. As discussed in this thread, miss-shifting at redline is bad because you can rev the engine well beyond it's design limit.
Old Jan 20, 2008 | 03:29 PM
poorhonda's Avatar
Default Re: (Hardedge)
what about when i chip it isnt it going to red line alot higher how bad is that goin to be on her
Old Jan 20, 2008 | 03:37 PM
bigD's Avatar
just because you chip your ecu does not mean you can rev it higher than stock. Your gona need to upgrade your valve train and cams if you want to make power that high
8dxhatchy8
Feb 24, 2009 05:31 PM
Razr2
15
Jan 1, 2008 10:24 PM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
Fatty_1775
Jan 21, 2003 07:06 PM
sicivic
12
Jan 23, 2002 06:46 PM
