H23 head swap?
Old Jan 19, 2008 | 05:02 PM
Biggz105's Avatar
Default H23 head swap?
I was told that i can swap an h22 head to an H23. comments on this please.
Old Jan 19, 2008 | 05:08 PM
Hawkze_2.3's Avatar
Default Re: H23 head swap? (Biggz105)
Yes, it's been done a billion times and there's tons of documentation on it. Check the Prelude FAQs at the top of the page.
Old Jan 19, 2008 | 05:26 PM
Biggz105's Avatar
Default Re: H23 head swap? (Hawkze_2.3)
i found an h22A4 head thats got skunk2 spring retainers, and skunk2 spring street springs. would that change anything?
Old Jan 19, 2008 | 05:37 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Biggz105 &raquo;</TD></TR><TR><TD CLASS="quote">i found an h22A4 head thats got skunk2 spring retainers, and skunk2 spring street springs. would that change anything?</TD></TR></TABLE>
Change anything related to the swap? No, it's just a different valvetrain....
Old Jan 19, 2008 | 09:11 PM
Biggz105's Avatar
so i wouldent have to change anything, or replace anything with that if the rest of the motor is stock?
Old Jan 19, 2008 | 09:32 PM
vlang29's Avatar
https://honda-tech.com/zerothread?id=510617
25 pages of freakin everything you need to know and then some
Old Jan 20, 2008 | 03:00 AM
Acidcrakker's Avatar
You will probally need a tuning system in one form or another with the Vtec head and up graded valve train.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Biggz105 &raquo;</TD></TR><TR><TD CLASS="quote">so i wouldent have to change anything, or replace anything with that if the rest of the motor is stock?</TD></TR></TABLE>
Old Jan 20, 2008 | 07:33 AM
Biggz105's Avatar
Default Re: H23 head swap? (Acidcrakker)
money terms. what would be ceaper. do the head swap, or swap the motor for an h22?
Old Jan 20, 2008 | 07:36 AM
lmAo.
Depends how skilled you are. H22 head swap and you need a tuning system, a dyno, and a h22 head.
A full motor swap you need a full H22 and a new ecu. Not to mention all the bells, dings, and whistles that do with a new swap.
Old Jan 20, 2008 | 07:43 AM
Biggz105's Avatar
so i dont need anything other than the head to do the swap?
Old Jan 20, 2008 | 07:53 AM
The awnser you want to hear is ''No you dont need anything else, its a piece of cake''
The real awnser is ''You need to search more about the topic, its more than just slapping a Vtech head on and go. There are a lot of varaibles you need to look up''
Old Jan 20, 2008 | 08:06 AM
h23vtak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">The awnser you want to hear is ''No you dont need anything else, its a piece of cake''
The real awnser is ''You need to search more about the topic, its more than just slapping a Vtech head on and go. There are a lot of varaibles you need to look up''</TD></TR></TABLE>
LOL @ VTECH
Old Jan 20, 2008 | 08:08 AM
Biggz105's Avatar
yeah, i just want to know what i need basic parts wise. but detailed, like do i need to get a special gasket for the h22 goin on the h23. i just want to go ahead and get the parts i need. and for that head with the skunk2 spring retainers and street springs, i may not even do that. its just an idea.
Old Jan 20, 2008 | 11:30 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote"> H22 head swap and you need a tuning system, a dyno, and a h22 head. </TD></TR></TABLE>
dude.. do your research
takes a lot more than just a head and a dyno.. you need a p13 to run vtec. you need a h22 intake manifold. you need an h22 crank gear, you need a h22 water pump, ETC ETC ETC. No, it does not NEED to be tuned if you have stock internals and are using a p13. It will make more power if it is tuned, like any car, but it is not absolutely necessary.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Biggz105 &raquo;</TD></TR><TR><TD CLASS="quote">so i dont need anything other than the head to do the swap? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Biggz105 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i just want to know what i need basic parts wise. but detailed, like do i need to get a special gasket for the h22 goin on the h23. i just want to go ahead and get the parts i need. and for that head with the skunk2 spring retainers and street springs, i may not even do that. its just an idea.</TD></TR></TABLE>
like i said before, https://honda-tech.com/zerothread?id=510617
has a list of EVERYTHING YOU NEED TO DO THE SWAP. If you can't read that thread, you can't do your head swap.
Old Jan 20, 2008 | 11:35 AM
vlang29's Avatar
the skunk2 springs and retainers will be fine as long as the cams are stock. If the cams aren't stock, you will NEED to get it tuned on a dyno
Old Jan 20, 2008 | 12:04 PM
Biggz105's Avatar
Default Re: H23 head swap? (vlang29)
Hah. alright, thanks a lot bud
Cho0se
22
May 16, 2013 07:24 AM
90AccordSi
May 31, 2005 02:27 PM
VTECLuDe96
Jun 7, 2004 12:00 AM
IcePenguin
Apr 6, 2004 07:24 AM
