d16y7 piston vs d16y8 pistons
Old Jan 19, 2008 | 04:01 AM
zenon8890's Avatar
Default d16y7 piston vs d16y8 pistons
are they the same?!
somebody post a pic plz
Old Jan 19, 2008 | 10:44 PM
zenon8890's Avatar
is is that hard question?
Old Jan 20, 2008 | 12:13 AM
ridin98civic's Avatar
Default Re: d16y7 piston vs d16y8 pistons (zenon8890)
the y7, y8, and y5 all share the same shortblock
Old Jan 20, 2008 | 01:09 PM
zenon8890's Avatar
ok i'm putting a d15b vtec head on the d16y7 block, which timing belt i should use?
Old Jan 20, 2008 | 01:11 PM
jdmracer12's Avatar
check the faq
Old Jan 20, 2008 | 01:51 PM
zenon8890's Avatar
i did, but all they talked about is the diffrent
Old Jan 20, 2008 | 02:50 PM
jdmracer12's Avatar
Default Re: (zenon8890)
well if the jdm d15b vtec head that you are using, that head is the same head as the usdm d16z6 head. there is a writeup on that in the faq. if its the d15 vtec-e head, then I dont know. hope this helps
Old Jan 22, 2008 | 05:50 AM
zenon8890's Avatar
yes its a jdm vtec d15b, and i found the write up but i cant see it, they wont let me
Old Jan 22, 2008 | 06:23 AM
jhammond_82's Avatar
Reject Papi
a little of subject. but cant you use isuzu pistons in one of the d series engines for a boost in compression?
Old Jan 22, 2008 | 01:55 PM
zenon8890's Avatar
u mean susuki vitara pistons, not isuzu, i dont want low compression i wanna cheap 20 HP more on my lx civic untill i have enough money for a K swap
Old Jan 22, 2008 | 02:02 PM
boosted92hatch's Avatar
all those pistons are the same, ignition timing will in fact never be correct
Old Jan 22, 2008 | 11:28 PM
zenon8890's Avatar
Default Re: (boosted92hatch)
why?
Old Jan 23, 2008 | 12:44 AM
ninethree-civic's Avatar
* B A N N E D *
ill check the EPC tommorrow after i finish writing this POS 6 page essay
Old Jan 23, 2008 | 06:38 AM
speedooo's Avatar
Default Re: (jdmracer12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmracer12 &raquo;</TD></TR><TR><TD CLASS="quote">well if the jdm d15b vtec head that you are using, that head is the same head as the usdm d16z6 head. there is a writeup on that in the faq. if its the d15 vtec-e head, then I dont know. hope this helps</TD></TR></TABLE>
theres an obd2 jdm d15b head that uses the same cast as a y8 head
Old Jan 23, 2008 | 06:46 AM
97Ej6mike's Avatar
Default Re: (speedooo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo &raquo;</TD></TR><TR><TD CLASS="quote">
theres an obd2 jdm d15b head that uses the same cast as a y8 head</TD></TR></TABLE>
X2.
Old Jan 14, 2010 | 05:48 PM
SikofFalln's Avatar
Y7 and Y8 pistons are not the same. Look up the part # and you will see that they are different.
Old Jan 15, 2010 | 12:48 AM
honisoto's Avatar
y8 has a little higher compression due to the head.
Built_d15b
Aug 9, 2017 08:02 PM
98jdmcivic98
Mar 27, 2012 07:34 AM
SprayinCX
10
Apr 7, 2003 11:45 AM
JaiDM
15
Apr 4, 2003 04:19 PM
