my MPH is jumping from 60-80-60-80-70-90 and so on.......
Old Jan 18, 2008 | 04:56 PM
b20vtech's Avatar
Default my MPH is jumping from 60-80-60-80-70-90 and so on.......
sup guys,
i have a 94 cx hatch, it's got a jdm b16 swap with a obd2 GSR tranny, i notice that when im on the freeway in 5th gear going 60 at a steady pase, my MPH gauge keeps on jumping back and forth from 60 to 80 back to 60 to 85 and so on....
what can it be?
Old Jan 18, 2008 | 05:04 PM
CF_EM1's Avatar
i can tell you excactly what the prob is ur ignitor is bad in ur dizzy u can only buy them from the dealer 120 big ones or get a new dizzy
Old Jan 18, 2008 | 05:08 PM
b20vtech's Avatar
Default Re: (CF_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CF_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">i can tell you excactly what the prob is ur ignitor is bad in ur dizzy u can only buy them from the dealer 120 big ones or get a new dizzy</TD></TR></TABLE>
so ignitor is what cause the MPH gauge to jump? wow i thought ignitor was for RPM gauge??
Old Jan 18, 2008 | 05:17 PM
z6hatchboy's Avatar
Default Re: (b20vtech)
^^^ true, check the vss man.
Old Jan 18, 2008 | 05:33 PM
IanB's Avatar
If the car was OBD2 the VSS would throw a CEL, now sure about OBD1. If that's not it you're looking at a bad speedo head.
Old Jan 18, 2008 | 06:04 PM
wangkata's Avatar
Default Re: my MPH is jumping from 60-80-60-80-70-90 and so on....... (b20vtech)
might be ur speedo, if vss is bad it give u CEL 17 I might be wrong...
Old Jan 18, 2008 | 06:06 PM
b20vtech's Avatar
oh and sometimes my MPH gauge just drops dead, say if i punch it hard then it just dies....
Old Jan 18, 2008 | 06:07 PM
b20vtech's Avatar
Default Re: my MPH is jumping from 60-80-60-80-70-90 and so on....... (wangkata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wangkata &raquo;</TD></TR><TR><TD CLASS="quote">might be ur speedo, if vss is bad it give u CEL 17 I might be wrong... </TD></TR></TABLE>
so i have to replace my speedometer? or is there a way to fix it?
Old Jan 18, 2008 | 06:08 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">
so i have to replace my speedometer? or is there a way to fix it?</TD></TR></TABLE>
Sounds like a loose connection, most likely to the speedometer.
If it was to the VSS it may pop a code - then again, it may not.
Since cluster's are a dime a dozen since hondas are so common - throw in another cluster from a friend's car temporarily and see if it does the same.
There's no place in the US that has lack of civics.
Old Jan 18, 2008 | 06:12 PM
95dxsir2's Avatar
please do tell
sounds like a bad connection to the vss. You should have a code in the ecu. The only way to find the problem is by load testing the wires, or just replacing the vss.
Old Jan 18, 2008 | 06:13 PM
95dxsir2's Avatar
Default Re: my MPH is jumping from 60-80-60-80-70-90 and so on....... (Syndacate)
you bastard, i was typing while u posted, arrrrgh.
Old Jan 18, 2008 | 06:16 PM
Syndacate's Avatar
Default Re: my MPH is jumping from 60-80-60-80-70-90 and so on....... (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">you bastard, i was typing while u posted, arrrrgh. </TD></TR></TABLE>
There's no use in replacing the VSS when you don't know what the problem is. I'm sure the OP knows one other person that has a same gen Honda - plug in the cluster and see if it does the same - takes 15 minutes tops (including the drive).
Old Jan 18, 2008 | 08:59 PM
mckrank313's Avatar
I agree with syndacate. His test is easy and free to try at first. You can also check under the hood and check the vss plug make sure it's connected right (i.e. unplug and plug it back in see if that fixes problem) Also make sure that it's not just moving around freely, try to make sure it stay's pretty still.
But the gauge cluster is also an Idea
Old Jan 19, 2008 | 01:54 PM
b20vtech's Avatar
thanks for all the inputs, i apreciate it
LS94tegra
Jan 25, 2008 11:46 AM
lv6l
Mar 31, 2006 05:40 PM
GTA
Jul 18, 2004 06:46 PM
madfish
Jan 24, 2004 08:18 AM
JDM CTR EK
Jun 24, 2003 03:04 PM
