Chrome door trim on the 4 door 98+ integra
no...all you can do is add chrome lining to the wheel wells and door jambs, maybe even the hood...that would really set it off...que?
jk....you should be able to, but i will offer no real input because i have never done this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20sedan »</TD></TR><TR><TD CLASS="quote">Sell it and buy a 1995 sedan, no chrome trim there.</TD></TR></TABLE>
haha no i like my 98
Thanks everyone, I may try to paint it.. or see if it can be pulled off...
there is no problem painting it. if your worried about it you can purchase special paint but regular paint will work just fine. just make sure its a clean surface before you paint. your lucky i have 6 years of painting experience
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRD^sam »</TD></TR><TR><TD CLASS="quote">I painted my sisters black on her 00 FW gsr, has chipped/flaked yet</TD></TR></TABLE>
you mean it hasnt?
you mean it hasnt?
Rough up the crome with some sand paper first, though, before you paint. I did this and it worked great. I power washed the car last week and chipped a lot of it away without even noticing it.
I don't think I put enough coats on. I'm going to have to re-do it sometime soon.
you power washed it and it came off because it wasnt clean enough. you need to use wax and grease remover. on top of that 3 light coats of color and 3 light coats of either clear or flat clear depending on your taste will do the trick. good luck
