Welding tips for turbo housing
i have to weld a 90 elbow onto a turbo housing. I will be using a dynasty 200dx with 3/32 red. Any tips for settings or suggestions for welding cast aluminum?
DO NOT, use a green (pure) tungsten with your dynasty!!! Good way to hurt the machine.
Green tungstens suck anyways, use a ceriated or zirconiated, zirconiated makes for the best welds especially with inverter machines.
Grind the area you going toweld, make sure its fresh and clean, and have at her.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech »</TD></TR><TR><TD CLASS="quote">wire brush it good with a ss wire brush.
pre-heating will help.
use green (pure tungsten) if you have it rather than red.
here's one i did a while back:
that excatly the direction i need to go. is that just a but weld using the same ID as the turbo? I do have 1/16 ceriated as well but i think that might be to small
</TD></TR></TABLE>that excatly the direction i need to go. is that just a but weld using the same ID as the turbo? I do have 1/16 ceriated as well but i think that might be to small
1/16 is too small, use 3/32 and either 1/16 or 3/32 5356 filler. I recommend zirconiated for the dynastys especially. I do this modification to turbos fairly regularily with my dynastys (2oodx and 300dx). Runa bout 140-150 amps, balance at 70, freq at 200. After you prep the joint use some acetone on it and your filler. Should come out nice!
[QUOTE=dave@passenger]1/16 is too small, use 3/32 and either 1/16 or 3/32 5356 filler. I recommend zirconiated for the dynastys especially. I do this modification to turbos fairly regularily with my dynastys (2oodx and 300dx). Runa bout 140-150 amps, balance at 70, freq at 200. After you prep the joint use some acetone on it and your filler. Should come out nice
