Side markers
Side markers
I have read but still confused, how do you make the side markers stay on, and also blink with your blinkers my side markers only have 2 wires coming out of them they are JDM Stanely side markers? so any help would be greatly appreciated!
Re: Side markers (Shaynepolevault)
if you wire them into your corner lights they will have the same characteristics as them. stay on and flash both. you will use the red and green wired (i think) and it should do what you want.
Re: Side markers (93egSLEEPER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">if you wire them into your corner lights they will have the same characteristics as them. stay on and flash both. you will use the red and green wired (i think) and it should do what you want.</TD></TR></TABLE>
So instead of grounding out the side marker you hook the ground wire to the wire that blinks on the corner light?
yes. if you want it to stay on all the time w/ your corners and and blink then you wire them with the same wires. (the sides will blink opposite the corners) there will be no use for a ground in that case.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">yes. if you want it to stay on all the time w/ your corners and and blink then you wire them with the same wires. (the sides will blink opposite the corners) there will be no use for a ground in that case.</TD></TR></TABLE>
Alright thanks again! you the man
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaynepolevault »</TD></TR><TR><TD CLASS="quote">yeah just did it worked thanks a lot</TD></TR></TABLE>
sweet good news... im doing a set this weekend myself. haha
Unjockable
01-27-2004 07:25 PM
