Which axles to use with a jdm B18cR engine swap
I bought a jdm type r motor (98+) from hmotorsonline.com and I'm going to be putting it into a 99 integra ls with the stock 4 lug hubs. They told me the original axles I have won't work with the motor though? Which ones will I need?
Your stock axles will work, you might get fresh ones since your taking them out
anyway. I have 91 axles and half shaft on my b18c5 they work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89sparks »</TD></TR><TR><TD CLASS="quote">He told me that they wouldn't work because the stock inside diameter size in a jdm engine tranny is larger then the stock id on a usdm b18b. Is he just bullshitting?</TD></TR></TABLE>
i think this dude doesn't know what he is talking about....
there is a 36mm OUTTER axel that is on the new ITR for 5 lug but they (b series) use all the same inner inputshafts
