knock knock knock knock knock
Old Jan 17, 2008 | 01:12 PM
Fat Chick Magnet's Avatar
Default knock knock knock knock knock
Problem fixed. My cluster/head unit started to dim out and my alternator died. I replaced it and that sound went away after beating on my car the same way i did before.
Modified by Fat Chick Magnet at 9:12 AM 1/18/2008
Old Jan 17, 2008 | 02:23 PM
Kevlar1's Avatar
Default Re: knock knock knock knock knock (Fat Chick Magnet)
BOOOM!
Old Jan 17, 2008 | 04:08 PM
nice. so i shouldn't drive my car anymore?
Old Jan 17, 2008 | 04:18 PM
BUT, every time i pull on throttle cable for the rpm to go up the sound goes away then when it drops back down to normal idle RPM the sound comes back.
Rickdrizzle's Avatar
your car is gonna blow! nos nos nos!
Old Jan 17, 2008 | 04:20 PM
Default Re: (Rickdrizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rickdrizzle &raquo;</TD></TR><TR><TD CLASS="quote">nos nos nos!</TD></TR></TABLE>
Old Jan 17, 2008 | 04:32 PM
PyroProblem's Avatar
Default Re: (Fat Chick Magnet)
Possibly the beginning of a rod knock?
After beating on it,the oil is probably really hot ~ 250F. Hotter oil = thinner oil...
Oil cools a bit, slightly thickens(maybe) and knocking isnt as apparent...
Just a theory.
Id pull the pan and inspect the rod bearings...Dont want to ruin a good ITR engine...Might still be a chance to save it...
Old Jan 17, 2008 | 05:16 PM
festivagt's Avatar
Default Re: (PyroProblem)
Do you have a oil pressure gauge installed? It'll tell you alot. Of course It sounds like low oil pressure. When is the last time you changed your oil? Did you use a oil filter with a 'poppit' valve in it? (The oil filter gets plugged and the oil pressure pops the valve open so the engine doesn't starve for oil) Some of your cheap filters don't have a poppit in them and they just plug up and don't open to allow oil to get to the rest of the engine. Hence your noise. Of course you never know it could just be somthing as dumb as a plugged oil pickup in the pan. You have some homework to do. But if it is knocking you need to fix it or say goodbye now.
HENRY
Old Jan 18, 2008 | 08:12 AM
fujiwara takumi
Sep 1, 2006 09:51 AM
cobra2326
Feb 14, 2006 10:03 PM
Brand
Aug 10, 2004 02:29 AM
an2ny888
Feb 11, 2004 03:54 PM
