Clutch Line Leak
I thought mine was some where in the Line or at the Damper also because I didn't see a leak any where else.
I decided to remove the entire Clutch Line and Damper and replace it with a SS Line instead. And also go ahead and replace the Clutch Master Cylinder and Slave Cylinder while I was at it.
On the new Slave Cylinder the Bleeder Screw was a weak piece of junk and it broke and ruined the new Slave, so I reused the old one.
So a month later, the reused Slave is the problem, or went bad with the new setup. It had a pin hole leak on the back side of it. So I ended up having to take it all apart again, but this time in the parking lot of Walgreen's. I can't even explain how fun that was...
Check the floor inside the car to see if it is leaking from the Master. Check the Slave and the Bell Housing of the Transmission to see if it's leaking.. Have someone repeatedly push on the Clutch Pedal and see if you see it leaking from some where in the line or anywhere else.
Here's some threads on the SS Line Option:
https://honda-tech.com/zerothread?id=1210919
https://honda-tech.com/zerothread?id=1689666
Whether you do it or not, they're good reads.
And this is where I had my SS Line Made to my Spec. http://techna-fit.com/
If you'd like info on my Setup just let me know. It's been working perfectly since June with no problems.
sideswiped
Jun 13, 2010 01:35 PM
rhdins
Nov 3, 2009 03:22 AM
