1993 honda del sol S swap
ok i searched, didnt find everything i was wondering about, im swapping in a JDM b16a2 from JSA motors into my 93 S right. it comes with:
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Starter
- Alternator
- Ignition Wires
- Headers
other than an engine wiring harness (i assume, its not listed)
is there anything else id need? im not really sure.
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Starter
- Alternator
- Ignition Wires
- Headers
go ahead and buy all the timing stuff and do the timing belt, waterpump replacement while the motor is out of the car. it's really easy with it in the car but you might as well do it while it's out.
Oh and and clutch and flywheel if you swing it.
if i were you, not really knowing the milage of the engine, i would break it down new piston rings, bearings, gaskets, just as an insurance......
i trust JSA motors pretty well. the honda dealership here actually recomended them. and i believe it comes w/ a clutch and flywheel
dont forget when you do a b series swap in a del sol that you need the del sol B series shiftlinkage (from the Si del sols that came with the b16a3) Other b series shift linkage will not work.
ok thanks for the info. ive heard people say you have to wire vtec in the sols, and ive heard other people saying all sols were pre wired for vtec any knowledge on that?
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Radyjr »</TD></TR><TR><TD CLASS="quote">if i were you, not really knowing the milage of the engine, i would break it down new piston rings, bearings, gaskets, just as an insurance......</TD></TR></TABLE>
lol...what? You've never done a swap before, have you? I'm not trying to insult you dude. But out of like the 20 billion swaps I did just last year...none of them needed rings or anything. If you get sold a bum motor, you send it back and get a used one. A lot of these motors only have like 30-60k on them. They shouldn't need all that crap.
A T-belt and water pump would be a good idea...and some accesory belts since the engines are steam cleaned and the accesory belts sometimes look very frayed and F'ed up. The clutches are usually good on the motors as well. Like I said...they usually only have 30-60k on them. If you want a clutch because you think you're going to beat the crap out of it or mod it for more power, then buy a clutch. They're cheap...and it's easy when the motor is out of the car. The T-belt and water pump is also easy when the motor is out of the car. BUY AN OEM T-BELT AND WATER PUMP!!!!!!!!!!!!!!!!!! DONT BUY AFTERMARKET FOR THIS!!!!!!!!!!!! You can find OEM stuff on ebay. Make sure its GENUINE HONDA. Very important. There are dealerships that sell these parts for around $150ish.
As for the clutch, I can highly recommend EXEDY. The stage 1 is a little more agressive than stock, but the modulation and pedal effort is very very good. It's a favorite of mine on NA apps. Stay away from cheap *** clutches. You dont need a "race clutch" unless you're building a race car.
You need nothing else except what comes with the swap. If it's a swap from a reputable place, that is.
You will need to so some minor wiring work. Add a subharness for VTEC, and for Knock. Then find an ECU pin out to put in the corresponding pins. Go to a junkyard, and take a few ECU connectors to use as a pin and wire source. Or use the ECU pin out/wiring diagram to see if the car is allready eqipped with the VTEC wiring. It's probably without the knock wiring, though.
It's very easy. It bolts in. If you need a step by step on how to do a swap with minimum effort, let me know. If you take it in certain steps, it goes a lot more smoothly.
well i havent heard that they are all wired for vtec, but it depends on what model you have. If you del sol originaly had a vtec motor than yes its wired in.
yeah hmotors is the best. i'd choose passwordjdm if hmotors was out or something but that's about it.
A buddy of mine bought a b16 for his ef and it came with a obd2 tranny but the motor was from a crx sir. and the axles were from something else.
the engine had all kinds of broken stuff on it. So yeah, save your self a headache and buy from a good company.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cDelSlo »</TD></TR><TR><TD CLASS="quote">yeah hmotors is the best. i'd choose passwordjdm if hmotors was out or something but that's about it.
the engine had all kinds of broken stuff on it. So yeah, save your self a headache and buy from a good company.</TD></TR></TABLE>
Exactly, i know of someone local who had bought a motor from JSA. Looking for an OBDII motor, It came with broken sensors, Blown HG and was OBDI. One cylinder was at 75!!.
Called them and the guy there just kept giving the run around, Even worse is they dont accept returns. And i dont know about your location but They have two locations, One in texas and One in canada, If youre going through the canada supllier thats a NO NO. Ontop of all that the motor came on some ratty *** pallet wrapped in about 2 inches of plastic wrap.
I dont wanna trash some company but i am.
holy **** i just checked hmotorsonline.com and the same exact **** is cheaper, and ive heard alot of great things about that place. the b16 sir2 complete change over is the same parts, and cheaper, wow
Try N1concepts.com. I think they're a honda tech sponsor...and they have awesome pricing.
$2800 B16B swaps, $1800 B16A OBD1 swaps, etc.
holy ****, i love you man lol, this site is awesome, how is their credibility? i dont want to buy from them just because theyre cheap and get a hot motor, or a POS
HMO is the **** for swaps. Got a GSR from them for my del sol. Wonderful customer service. If you need anymore questions answered im here man Ive done all my swaps in my delsol and in my friends delsols. I love the delsol Ill never get rid of mine.LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 63Bmechanic »</TD></TR><TR><TD CLASS="quote">holy ****, i love you man lol, this site is awesome, how is their credibility? i dont want to buy from them just because theyre cheap and get a hot motor, or a POS</TD></TR></TABLE>
Hmotorsonline is
X1000 for sure. I've recieved a few motors from that place. They have all been tip top. And VERY VERY clean (shiny, new looking). That's important to me because I'm a weird clean freak lol.
I've never bought from N1concepts....but they seem pretty legit. They even ran at the super street time attack and held a record spot for a while. I'm pretty sure they sponsor this site also. Just check what their warranty is like. If they have a 100% start up and and 100% completeness warranty, then DO IT. Make sure that if you receive the motor with a broken sensor or part, they will either replace it, or take the motor back. Call them up. Put up a post asking people about their reputation. Search honda tech for n1concepts. See if positive or negative **** comes up.
Good luck.
Hmotorsonline is
X1000 for sure. I've recieved a few motors from that place. They have all been tip top. And VERY VERY clean (shiny, new looking). That's important to me because I'm a weird clean freak lol.I've never bought from N1concepts....but they seem pretty legit. They even ran at the super street time attack and held a record spot for a while. I'm pretty sure they sponsor this site also. Just check what their warranty is like. If they have a 100% start up and and 100% completeness warranty, then DO IT. Make sure that if you receive the motor with a broken sensor or part, they will either replace it, or take the motor back. Call them up. Put up a post asking people about their reputation. Search honda tech for n1concepts. See if positive or negative **** comes up.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">
Hmotorsonline is
Yea my buddy got a obd0 b16 swap from Hmotors and damn it looks just about brand new
very impressed
Hmotorsonline is
X1000 for sure. I've recieved a few motors from that place. They have all been tip top. And VERY VERY clean (shiny, new looking). </TD></TR></TABLE>
very impressed
rexman
Aug 4, 2005 11:09 AM
