low idle?
Old Jan 17, 2008 | 12:03 AM
DOHChatchGUY's Avatar
Default low idle?
i think my b16a is idling low. its at like 500 or less. it just goes all the way down to the little stopper thing on the cluster. i think it used to be at around 700-800 before but could be wrong. im using a 12.5 lb. act flywheel if that helps.
Old Jan 17, 2008 | 12:21 AM
ek-g6's Avatar
Default Re: low idle? (DOHChatchGUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHChatchGUY &raquo;</TD></TR><TR><TD CLASS="quote">i think my b16a is idling low. its at like 500 or less. it just goes all the way down to the little stopper thing on the cluster. i think it used to be at around 700-800 before but could be wrong. im using a 12.5 lb. act flywheel if that helps.</TD></TR></TABLE>
i have a lighten flywheel too 12lbs, no change in idle, you should check your vacuum lines to see if anything is cracked, and if that doesnt work adjust your idle.
Old Jan 17, 2008 | 12:41 AM
Default Re: low idle? (ek-g6)
word. thanx ill try that when the sun comes up
darockstar
Mar 10, 2006 05:00 PM
chitownrida
Dec 9, 2005 02:24 PM
98cwitr
Jan 22, 2004 06:31 PM
petrv
Sep 25, 2003 06:11 AM
Spade
Jan 8, 2003 01:51 AM
