B20 Cams
Old Jan 16, 2008 | 10:11 PM
B20 Civic's Avatar
Default B20 Cams
I want to change my cam's on my B20 VTEC, running Arias pistons with 10.8:1 compression. I want to know if the compression is high enough to run the Buddyclub spec 4's??? If not please give me some options that will work with that compression.
Here is some mods:
Omni power springs and retainers
Skunk valves
B16 head port & polished
Arias pistons
Eagle rods
ARP head bolts
Hytech copy
Blox intake
Skunk 68mm T/B
Buddyclub exhaust
Any info please...
Old Jan 17, 2008 | 02:55 AM
B20 Civic's Avatar
Default Re: B20 Cams (B20 Civic)
BUMP
Old Jan 17, 2008 | 10:56 AM
b19coupe's Avatar
Those cams will work o.k. with 10.8:1 compression on a B20VTEC.
Old Jan 17, 2008 | 09:09 PM
B20 Civic's Avatar
Default Re: B20 Cams (b19coupe)
Do you think there is a better route I can go? Pro1's mabe...
Old Jan 18, 2008 | 06:09 AM
2.0TEC's Avatar
I have a very similar setup except i have 12:1 and run CTR cams which is the best route if ur lookin 180 to 200whp and its turn key reliable.. if ur lookin for more power skunk2 stage 2 pros give great power and are somewhat better than the buddyclub setup.. FYI..I also found that crower makes a 2.3L stroker kit for the b20
Modified by 2.0TEC at 7:30 AM 1/18/2008
Rpicano
12
Apr 23, 2013 12:44 PM
egycasper16
Feb 15, 2010 08:53 PM
Mikej425
May 14, 2008 05:27 PM
B20 Civic
Jan 29, 2008 05:58 AM
Pony_Fed95
Sep 12, 2005 07:09 PM
