need ideas .... car not starting
Old Jan 16, 2008 | 04:18 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default need ideas .... car not starting
here is the deal.... car was boosted before.... everything worked fine...
pulled the motor to build it... its in. ready to go, relocated the battery to front floor board.
starter doesn't turn over when i turn the key, starter turns when i jump it via starter power to starter signal....
checked all the fuses, jumped the clutch switch
any ideas?
Old Jan 16, 2008 | 04:26 PM
Archidictus's Avatar
Unceasing Measure
Default Re: need ideas .... car not starting (tannerLSt)
If it's not clicking or anything when you turn the key, assuming your power wire is hooked to the proper location, your signal wire simply isn't getting a signal. Make sure it's attached properly to the solenoid.
Does the rest of the car come to life when you turn the key? Are you sure all your ground wires are properly connected?
Old Jan 16, 2008 | 04:33 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: need ideas .... car not starting (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">If it's not clicking or anything when you turn the key, assuming your power wire is hooked to the proper location, your signal wire simply isn't getting a signal. Make sure it's attached properly to the solenoid.
Does the rest of the car come to life when you turn the key? Are you sure all your ground wires are properly connected?</TD></TR></TABLE>
i've taken the starter signal wire off and on over and over, its connected properly
and yes the rest of the car comes to life, fuel pump primes, all lights come on in the dash, its a brand new optima battery... and yes all grounds are connected properly(i don't have the valve cover ground but i didn't before and it started fine all the time)
can't be the ground if its starting when i jump the starter and it works
Old Jan 16, 2008 | 04:37 PM
95dxsir2's Avatar
you also might have to down the wire gauge ie. 12 ga. because of the length (for the solenoid). If that's no the problem it would help anyways. You might also have to do the same for the battery cables. get a test light and check for voltage at the stater when the key is turned to start.
Old Jan 16, 2008 | 04:40 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: need ideas .... car not starting (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">you also might have to down the wire gauge ie. 12 ga. because of the length (for the solenoid). If that's no the problem it would help anyways. You might also have to do the same for the battery cables. get a test light and check for voltage at the stater when the key is turned to start. </TD></TR></TABLE>
battery cables are 1 gauge.... used the stock wires for altenator and starter wire that goes to fuse box
and if the starter signal wire was getting voltage it would start ! i need to get a test light though!
Old Jan 16, 2008 | 04:49 PM
95dxsir2's Avatar
yes.
you got a cheapy multimeter?
Old Jan 16, 2008 | 04:51 PM
Johnny Ricer's Avatar
Fudge the test light invest in a multimeter, It will help you in the long run it sounds like your grounding out. You need to go over all your wiring again get a multimeter and test wires at different locations to find where power is being lost. As archiditcus asked do das and cluster lights illuminate when the key is turned to the on position?! Check your engin and trans to Chassis ground cables over again and assure they are all on tight and directly touching a clean metal surface no rust or dirt in the way.
Old Jan 16, 2008 | 04:53 PM
pdotjones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">
any ideas? </TD></TR></TABLE>
when you jumped the switch, was the connection good? was it jumped when it was boosted?
Old Jan 16, 2008 | 05:45 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: need ideas .... car not starting (Johnny Ricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Ricer &raquo;</TD></TR><TR><TD CLASS="quote">Fudge the test light invest in a multimeter, It will help you in the long run it sounds like your grounding out. You need to go over all your wiring again get a multimeter and test wires at different locations to find where power is being lost. As archiditcus asked do das and cluster lights illuminate when the key is turned to the on position?! Check your engin and trans to Chassis ground cables over again and assure they are all on tight and directly touching a clean metal surface no rust or dirt in the way.</TD></TR></TABLE>
my buddy has a multimeter... i'll have to get him to come by... yes clutster lights illuminate.....
where i grounded the battery i sanded off the paint , and i've checked grounds (again i don't have the valve cover ground, but i didn't before either...)
Old Jan 16, 2008 | 05:47 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: need ideas .... car not starting (pdotjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdotjones &raquo;</TD></TR><TR><TD CLASS="quote">
when you jumped the switch, was the connection good? was it jumped when it was boosted?</TD></TR></TABLE>
i'm not sure if it was good or not, thought the switch might be bad, so i jumped it by putting two wires into the connectors to make the car think the clutch was in, and tried to start it....
what the hell do you mean was it jumped when it was boosted, its still boosted. and no it wasn't jumped before everything worked fine
Old Jan 16, 2008 | 05:50 PM
pdotjones's Avatar
what the hell do you mean was it jumped when it was boosted, its still boosted. and no it wasn't jumped before everything worked fine</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">here is the deal.... car was boosted before.... everything worked fine...
</TD></TR></TABLE> by saying before, it sounds like you went a different route other than boosted, n/a.......but any way, i'm willing to bet that its the connection when you tried to bypass the clutch switch..... with wires did you tap into? my clutch switch is bypassed so i can kinda tell which wires should be tapped....
Modified by pdotjones at 7:00 PM 1/16/2008
Old Jan 16, 2008 | 06:00 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
just added the valve cover ground and still nothing
Old Jan 16, 2008 | 06:01 PM
pdotjones's Avatar
Modified by pdotjones at 7:00 PM 1/16/2008</TD></TR></TABLE>
Old Jan 16, 2008 | 06:02 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
ya i pulled the motor to build it, and upgraded every part of my turbo set up...
the clutch switch is not bypassed anymore, since bypassing it didn't work for starting it... and there is only two wires to connect when jumping it..
Old Jan 16, 2008 | 06:22 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
to answer your question, i pulled the connector off the clutch switch, and ran a wire between the ports on the connector like you would do your ecu when checking the codes
Old Jan 20, 2008 | 08:26 AM
95dxsir2's Avatar
Default Re: (tannerLSt)
dude, it's not hard at all to check a no crank/no start. So fuc*in listen.
where' the test light/multi-meter? it's so much more easier with a test light. i don't have the wiring diagram in front of me, but i'm sure it goes something like this.
low amp 12 volt feed from ignition switch to clutch switch, feed goes from switch to starter.
When i swapped my d15 AT to b16 MT, i had to exchange brake and clutch pedals.
there we 2 switches on the ctlutch pedal assembly, but i didn't care about them (no use).
Sooo. there might also be another clutch switch (disengeged) in the circuit.
All you have to check is the power feed, there's no ground, the starter grounds itself
Old Jan 21, 2008 | 01:20 AM
Default Re: (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">dude, it's not hard at all to check a no crank/no start. So fuc*in listen.
You are wrong testing with a test light is not better than using a mutimeter, A test light only shows that there is in fact voltage flowing through a line. With his problem he could be getting voltage through the line causing your said light to illuminate. But the eletrical curren may be to weak to do anything do to a parasitic draw or bad connection. Using a multimeter is basically the only way to go on newer cars when diagnosing an electrical problem.
When there are two switches on a clutch pedal it doesnt mean they both activate starting ability. The secondary switch you had was because the pedal assembly most likely came from a vehicle equipped with cruise control. The second switch is only to deactivate cruise when the clutch is engaged.
He also stated all grounds were checked already and were properly attached.
OP:
curious to here what the news is has anything been fixed or are you still having the current problem?
Old Jan 21, 2008 | 03:18 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
yes its fixed guys, it was my ignition switch... replaced and she's starting fine
billyhoe
Dec 21, 2020 11:52 AM
2x0
Apr 29, 2018 09:35 AM
entoy
10
Aug 14, 2013 04:21 AM
slowassBubble
May 15, 2011 07:50 AM
bayoufrogg
Oct 24, 2006 08:18 PM
