i read all the faqs and could not figure this out
i have heard that you can use integra type r swaybars on a 92-95 civic. Is this true? If so is there a specific year integra that can only be used? What size sway bars are they? Any modification needed to be done or is it a direct swap in? If they can be swapped in, does anybody have some forsale?
Yes, you can put 94-01 Integra sway bars on.
FRONT
94-01 GSR/GS, 99-01 LS= 24mm
97-01 ITR = 24mm
94-98 LS/SE/RS = 22mm
REAR
94-01 GSR = 14mm
94-01 LS/SE/GS = 13mm
97-01 ITR = 22mm
The fronts are a complete bolt assuming you have front LCAs that accept sway endlinks. The rears are a bolt on if you have the brackets and rear LCAs that accept the sway. Reinforcement brace (ASR, Comptech) is needed for rear sway bars 19mm or larger.
FRONT
97-01 ITR = 24mm
REAR
94-01 GSR = 14mm
97-01 ITR = 22mm
Do the skunk 2 lower control arms support the rear sway bar? My plan was to get the ASR brace, sk2 LCAs, and i guess, now the 22mm itr rear sway.
My ride is a 92 vx hatch. I am almost positive that the control arms will not work in the front without replacing them since my hatch was build strictly for economy. Where could i find some LCA's for the front to make the front 24mm sway bar work for me? Any aftermarket ones avaliable? I couldn't find anything but rear LCA's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prudz_lude »</TD></TR><TR><TD CLASS="quote">Do the skunk 2 lower control arms support the rear sway bar? My plan was to get the ASR brace, sk2 LCAs, and i guess, now the 22mm itr rear sway.
My ride is a 92 vx hatch. I am almost positive that the control arms will not work in the front without replacing them since my hatch was build strictly for economy. Where could i find some LCA's for the front to make the front 24mm sway bar work for me? Any aftermarket ones avaliable? I couldn't find anything but rear LCA's</TD></TR></TABLE>
Yes, Sk2 LCAs will work in the rear. You need front control arms from a 92-95 Civic EX, Si, or LX or 94-01 Integra. Try a junkyard or H-T marketplace to find the front control arms. No aftermarket front LCAs will give you endlink mount points.
ok got one more question. I found a brand new technique suspension rear sway bar in my city for about $140. however, it does not seem like he knows what size it is. What size did this sway bar come in?
cafrog
36
Jun 18, 2009 02:37 PM
