ITR Rear Sway, Quick Question
Hey everyone, just picked up a 92 Civic Hatch CX and I was looking in to the ITR 22mm Rear sway bar. I have a 14mm GSR rear sway in my garage and i have the D bracket and the endlinks still on it, probably needs new bushings.... but anyways can i just order the 22mm rear sway and use the GSR sway bar mounts? and is it a "MUST" to have the BSQ or Beaks mounting kit?
btw, before u start flamin me on ripping my subframe, the hatch is stripped and will be running 400-450lb/in springs in the rear.
THANKS!!!
THANKS!!!
Re: ITR Rear Sway, Quick Question (D21X)
Oh yea i forgot to say that too, i'll either be getting integra LCA's or the Megan LCA's.
btw, integra LCA's work too....
before you go out and buy Megans LCA's I would check the thread about them just for a pointer.
https://honda-tech.com/zerothread?id=984808
be professional
This may help:
http://geocities.com/bretq/swaybar_install.html
You should get some sort of subframe reinforcement. Keep in mind that ITR rear subframe is not the same as other Integras or Civics.
B20EF
07-09-2008 04:44 AM
opeth13
06-02-2004 05:46 AM
