ITR HEADER
if u have d series engine. then its a no no .but if u have b series swap. it will bolt on to the block but the problem is cat conveter flange u might need to have a muffler shop cut and reweld the flange of cat converter.
Can you be a little more specific in exactly what you're asking?
Are we talking a 2.5'' collector ITR header, or a Us-spec one?
What kind of car and engine do you have?
answer is no, and here's why:
if its the jdm 2.5" collector, it is to big for the flange on the ex cat.
and either way the flange is off by 90 degrees
for any further info..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Can you be a little more specific in exactly what you're asking?
What kind of car and engine do you have?</TD></TR></TABLE>
Well without any engine info we cannot answer anyways.
I can tell you a way it would bolt up, no problem:
Civic EX has a B18C5 engine, stock Ex catalytic convertor, and he installs a DC header intended for a USDM ITR.
100% bolt-on affair.
The 92-95 Si/EX, 94-01 Integra non-GS-R, and 96-00 EX and Si cats are diensionally identical. My wife had a 1992 Si HB with a B16A2 swap and her stock 92 Si cat was 100% identical size wise, flange wise, as the 1999 donor Si convertor. We used the newer convertor, but it would have worked either way.
My old 1992 Si HB had a B18C5 swap in it and the factory USDM ITR manifold/a pipe bolted up to my Si exhaust piping and stock ITR cat convertor with zero issues - a standard replacement header would be the same way.
...but all this means nothing if he wants a JDM header, or he has a stock D engine in which case hell no it won't work.
DelsolioGSR1996
Oct 2, 2007 02:33 PM
