Electric Load Detector
Im getting the signal for electric load and i can not figure out the problem i know my under hood fuse box is good its brand new and my ecu is also brand new i have no idea where the problem could be now? And it is causing my car to not start anymore how many grounds are under the hood and dash of a 1990 honda crx si?
or give me a call since i rarely get on here 7163730731 thank u
Modified by widerex90 at 9:39 AM 1/16/2008
or give me a call since i rarely get on here 7163730731 thank uModified by widerex90 at 9:39 AM 1/16/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by higgunscrx »</TD></TR><TR><TD CLASS="quote">do you have a upgraded ecu from an integra? cuz that will do it aswell. </TD></TR></TABLE>
What?! no no no
OP: check the grounds like everyone said, most likely the one on the thermostat. then the others
What?! no no no
i checked that ground i think my ELD might be expletiveed up or something i sanded the spot it bolts onto and everything and still nothing but i have no idea why my car wont start though any ideas?
Man all the posts on this site as well as others ALL PERTAINING TO this mystery NO START condition. Has nothing to do with starter. NO POWER ANYWHERE. Bat. is at 12.4........ I wish you good luck and if you found the problem PLEASE let me know as all other posts have not posted a final fix if there was one to there problem.
https://honda-tech.com/zerothread/2210563
here is my problem.
here is my problem.
