Inductive pickup for coil-on-plug (CDI)
Old Jan 16, 2008 | 08:16 AM
92TypeR's Avatar
FSAE
Default Inductive pickup for coil-on-plug (CDI)
I am trying to find a way to connect an inductive sensor on a Honda CBR F4i coil-on-plug. The RPM signal on our Superflow engine dyno only has inductive input, and unfortunately most coil-on-plug applications have no spark plug wires.
There are a couple ways it can possibly work.
A tool that somehow clips to or mounts to the coil, or a converter that will reference either the cam or crank trigger wheel and convert it into an inductive signal.
If anyone has experience with getting a similar setup to work, please let me know.
-Marshall-
Old Jan 16, 2008 | 08:40 AM
thesmogman's Avatar
Default Re: Inductive pickup for coil-on-plug (92TypeR)
If you have a short plugwire you can pull the coil and just use the wire as a jumper of sorts.
Or you can use the inductive pick-up on the coil's trigger wires. Try this first.
You also might be able to just lay the pick-up on top of the coil too.
jspeedy
Jun 26, 2010 05:04 AM
777
10
Jan 18, 2006 08:28 AM
mdixonjam
May 27, 2005 08:30 AM
f1uxx
Jul 29, 2003 01:33 PM
Kazmans94cord
Sep 27, 2001 09:02 PM
