plug wires
Old Jul 29, 2003 | 12:20 PM
f1uxx's Avatar
Default plug wires
i just got my obx 10.3 mm spark plug wires in the mail today and took the stock wires off and didnt think about the way they were plugged in , does it matter ? i tryed putting the new ones on and the car doesnt work right what did i do ?
Old Jul 29, 2003 | 12:33 PM
THC EK LSVTEC's Avatar
Default Re: plug wires (f1uxx)
yo check ur distributer
Old Jul 29, 2003 | 12:35 PM
f1uxx's Avatar
Default Re: plug wires (SCideGsR)
witch way do they go on the disributer
Old Jul 29, 2003 | 12:36 PM
mr.beeks's Avatar
Default Re: plug wires (f1uxx) firing order...
maybe you plugged them right
the firing order on the engine is starting from right (timming belt) to left
1-2-3-4
the firing order on the distributor is
starting from the bottom left then going upper left, upper right, lower right.
1-3-4-2
this should solve your problem...
Old Jul 29, 2003 | 12:52 PM
f1uxx's Avatar
Default Re: plug wires (f1uxx) firing order... (francisco flores)
yeah that worked just one last question.... the package came with 5 wires... the last wire has 2 connecter ends like the ones that connect to the distributer , there exactly does that go ?
Old Jul 29, 2003 | 12:56 PM
redlinegsr's Avatar
that is used if you have an external coil ie msd blaster or something like that...no need for it on stock ignition
Old Jul 29, 2003 | 12:57 PM
mr.beeks's Avatar
the extra wire is if you have an external coil..
wich really help out than those dinky honda coils that burn out..
Old Jul 29, 2003 | 01:12 PM
MooreBoost's Avatar
Default Re: plug wires (francisco flores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by francisco flores &raquo;</TD></TR><TR><TD CLASS="quote">the extra wire is if you have an external coil..
Honda coils are fine. Theyre are many pro draggers still running the stock ignition. And if you start having trouble with your car, check the wires first. Hate to break it to you but stock or NGK wires are preffered around here.
gmoore
Old Jul 29, 2003 | 01:23 PM
mr.beeks's Avatar
Default Re: plug wires (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">
gmoore</TD></TR></TABLE>
I hate the internal coil thats all but prefer the stock or ngk better as well.
and yeap prodragers do keep stock ignition but lets not forget that this is
a daily driven car and not a prodrager.
how many miles a prodrager put in his car during a season?
Old Jul 29, 2003 | 01:26 PM
MooreBoost's Avatar
I have no clue, but theyre all at WOT and under 20-25lbs of boost? Fact of the matter is Honda coils are fine, and will work for as long as you own the car.
gmoore
Old Jul 29, 2003 | 01:33 PM
f1uxx's Avatar
alright thanks for the help
Jaydeep
Apr 28, 2004 06:03 AM
KekeK-18
Mar 29, 2004 05:40 PM
bey
Oct 31, 2003 06:13 PM
Canonm7
Mar 30, 2003 12:33 PM
CM-R
May 21, 2002 09:41 PM
