screech sound from clutch?
Old Jan 16, 2008 | 12:07 AM
BB1LOViN's Avatar
Default screech sound from clutch?
Every once in a while when i shift (driving normally), after i engage the clutch id hear a loud screech sound(i can hear it inside and outside). It sounds as if im chirping tires..but im 100% sure im not.
any suggestions as to what it might be?
Old Jan 16, 2008 | 01:38 AM
Rosko's Avatar
Default Re: screech sound from clutch? (BB1LOViN)
throwout bearing?
Old Jan 16, 2008 | 05:43 AM
8_6 luder's Avatar
Default Re: screech sound from clutch? (Rosko)
yup
Old Jan 16, 2008 | 06:30 AM
vlang29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">throwout bearing?</TD></TR></TABLE>
X3
Old Jan 16, 2008 | 09:15 PM
BB1LOViN's Avatar
Default Re: screech sound from clutch? (vlang29)
crapp, i searched around for symptoms of a bad throwout bearing and most of them apply to my case.
Thanks a lot for the info guys
Old Jan 17, 2008 | 12:20 AM
BB1LOViN's Avatar
my bad guys, i meant to say that the screech sound is heard after i shift(once i release the clutch and it catches the gear)...so while the clutch is catching gear it makes the screech even and low rpms.
would it still be a throwout bearing?
Could i still just drive my car? I dont feel like getting a new clutch etc because im planning on selling the car anways.
Old Jan 17, 2008 | 06:02 AM
prelude_h22vtec's Avatar
this comes up all the time. i'm pretty sure its throwout. gotta replace mine. but i'm not removing the tranny without replacing the clutch too, so i'm waiting for that to start slipping.
Old Jan 17, 2008 | 01:30 PM
Inextricabledrvr's Avatar
Default Re: (prelude_h22vtec)
I am currently having the exact same problem. It sucks, but its more than likely the TOB. Mine mainly happens only at low rpms when I am releasing the clutch. Sometimes the sound is there and other times its gone. Im going to wait until my clutch starts going out as well.
Old Jan 17, 2008 | 01:41 PM
Blacktt7's Avatar
If (and that's a big IF) we are all having the same issue, does anyone else notice the clutch pedal feel a bit different when it does it. Almost like it wants to start engaging the clutch right after you start to lift your foot off the floor. That's the only time mine screeches so i've learned to pull it back out of gear pump the clutch once and do it again and it doesn't do it.
Maybe the TOB gets stuck due to some bad needle bearings???
Old Jan 17, 2008 | 07:31 PM
ludenoob99's Avatar
Default Re: (Blacktt7)
the TOB doesnt have needle bearings, its ball bearings and i highly doubt it is getting stuck although the screeching sound does lead me to belive its TOB related.
does the car have any other symptoms when this occurs? hard shifting, slipping, clutch chatter???
Old Jan 17, 2008 | 09:45 PM
Default Re: (ludenoob99)
As for my screeching noise. I am having some hard shifting issues along with clutch chatter, but no slipping. My clutch engages almost at the top. It seems like the clutch pedal is getting farther and farther from the floor.
Old Jan 17, 2008 | 11:37 PM
BB1LOViN's Avatar
Default Re: (Inextricabledrvr)
Yeah it only happens at low RPMs for me as well. I was wondering how long you guys think our clutches will hold up if we keep driving as is?
Old Jan 17, 2008 | 11:38 PM
BB1LOViN's Avatar
Default Re: (BB1LOViN)
so sooner or later my clutch will start slipping too?
Old Jan 18, 2008 | 04:16 AM
ludenoob99's Avatar
ok so if your getting hard shifting and clutch chatter there is most likely something bent or missadjusted. first test that the clutch is really your cause of the hard shifting. if it is hard to shift into all gears with the car on, turn the car off and see if it gets easier, if it does then the issue is clutch related. you could have a little bit of grease or oil on the clutch that will cause it to chatter, or something could be damaged to the disc itself or the pressure plate or the TOB. the hard shifting could also be from a worn out pilot bushing catching the input shaft splines sometimes makeing both a noise and you dissenguagement issues.
Old Jan 18, 2008 | 06:04 AM
lude98SH's Avatar
most hseries dont use pilot bushings
Old Jan 18, 2008 | 03:44 PM
BB1LOViN's Avatar
im not getting hard "jerky" shifts if thats what you mean.
but when I am releasing the clutch. Sometimes the sound is there and other times its gone. All of this usually happens at low RPMS only.
Also my clutch pedal feels a bit more soft now. My uncle says it could also be the pressure plate?
Old Jan 24, 2008 | 06:06 AM
bonster's Avatar
I'm having the same problem, the hard part is when I'm with a mechanic, the sound just won't come out. I tried to catch it one time & when I opened the hood & followed the sound, It's like coming from the radiator fan. Or I at least that's where it is closest. Where you able to get it fixed?
Old Jan 24, 2008 | 08:34 PM
BB1LOViN's Avatar
Default Re: (bonster)
i havent gotten it fixed yet.
ive been thinking about selling the car so im not putting anymore money into it. Ill just baby it until i sell it or replace the whole clutch etc later on.
goodluck with your car bro
not sure if its the same but my screetch sound tends to come out when i slip the clutch in, fast, at low rpms. Try it out maybe you can get the sound to come out.
Old Jan 24, 2008 | 10:57 PM
InitialJRift's Avatar
* B A N N E D *
mine is still doing the same thing, didn't bother with having Honda look into it because i'm just going to have them replace the clutch anyway, seems to do it more when it's cold, horrible sound, i also noticed that when coasting to a stop at a stop sign with the clutch in and not coming to a full stop then releasing the clutch when i try to let it back out the noise is extremely loud and annoying, like nails on a chalkboard
ps. like someone else said i've also found that you can feel when it's going to screech because the clutch engages extremely quick, if i put it back in neutral, let off the clutch, then push it back in and shift into 1st, it feels fine and won't screech
kenzo42
Oct 14, 2008 03:11 AM
k0rupt_ed
12
Nov 13, 2007 07:05 AM
924doorEG
Aug 27, 2007 02:07 PM
Probot
Apr 18, 2007 07:00 AM
EliTe 93Lude
Jul 27, 2006 06:58 AM
