92 civic hatchback engine code 3?
Old Jan 15, 2008 | 06:41 PM
Andrewk138's Avatar
Default 92 civic hatchback engine code 3?
3 MAP - manifold absolute pressure sensor...
anyone know whats wrong and how to fix?
Old Jan 15, 2008 | 06:43 PM
ek-g6's Avatar
Default Re: 92 civic hatchback engine code 3? (Andrewk138)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andrewk138 &raquo;</TD></TR><TR><TD CLASS="quote">3 MAP - manifold absolute pressure sensor...
anyone know whats wrong and how to fix?</TD></TR></TABLE>
get a couple of map sensors from the junkyard, and try them out, but before you do that, reset your ecu, and if it comes back on replace it. if not it was just a glitch..good luck
Old Jan 15, 2008 | 06:45 PM
Frozen E's Avatar
H-T White Ops
The poll options are great.
Old Jan 17, 2008 | 07:01 AM
Endo-land's Avatar
Code 3 is usually a wiring issue. If you recently did a swap and now have a motor with a throttlebody mounted map sensor, you need to use the firewall wiring to the throttle map.
speedooo
11
Jul 24, 2008 09:27 AM
FSS13foxtrot
Jan 20, 2008 06:23 AM
vtec25
Oct 6, 2004 08:26 PM
1BadCvC
Sep 13, 2003 07:01 AM
logistixz
Jun 20, 2002 01:06 PM
