96 civic with gsr swap keep getting codes P1454 ,P1452 , P0505 help!
Old Jan 15, 2008 | 02:20 PM
poorhonda's Avatar
Default 96 civic with gsr swap keep getting codes P1454 ,P1452 , P0505 help! any one
i just got done doing my first swap and i keep getting these codes P1454 ,P1452 , P0505
and it seems to run great the only thing is when i first start it and its cod it seems to idle very very high unti she is all the way warm . the motor is a 0bd1 that made into a obd2 everthing ls seems good but this and i got to go get it inspected
dose any one have the vac digram for a 95 gsr
Modified by poorhonda at 3:49 PM 1/15/2008
Old Jan 15, 2008 | 03:40 PM
SirRevvs's Avatar
Default Re: 96 civic with gsr swap keep getting codes P1454 ,P1452 , P0505 help! any one (poorhonda)
Here just to be a dick....
https://honda-tech.com/zerothread/1901557
Now a P1454 is a fuel tank pressure sensor (FTP) mrange or performance problem. Did you overfill that gas tank last time you filled up?
P1452 is not listed in the archives from what I could find so I dunno
P0505 is Idle control system malfunction what engine did you swap? Did you convert the iacv plug for 2 wire if your car is a dx? Or maybe its not plugged in. Or if you have a Y7 engine it may be a bad 3 wire iacv.
Here's how to convert the plug in case you went from a Y7 to something else
Well I can't copy the link but here;s the page, about halfway down you'll see "IACV 3 Wire Re-Pin Diagram"
http://technet.ff-squad.com/
Hope that helps
To make things easier just try jumping the two pin blue connector underneath your glovebox and counting the flashes, I'll be able to help you better that way. Its explained on the first link in my post
Old Jan 15, 2008 | 04:06 PM
poorhonda's Avatar
its a 96 civic ex it had a d16y8 in it and i put a obd1 b18c gsr into
dem0nk1d
Apr 26, 2017 08:29 PM
slamLOWnBANGIN
18
Apr 15, 2013 09:33 AM
SiRCiviC94
19
Nov 10, 2012 03:16 PM
lsvtecboi'95
Oct 6, 2007 06:18 PM
modifydaccord94
Dec 25, 2006 05:59 PM
