5 Lug Conversion Question!!
i *THINK* that you wont because you cant/arent switching to ITR LCA's on your car, just the trailing arm, front knuckle assembly. So your good my friend..
yeah in the front you will keep your setup, in the rear it depends on whether you wanna run the ITR rear lca which will give you a hole to run a swaybar. If you chose to run that then you will need to change rear shocks otherwise you can keep your current setup with your stock rear lca
JDM honey
Oct 4, 2007 08:59 AM
compwc18
Apr 9, 2005 03:54 AM
1337 Si
19
Nov 17, 2003 02:48 AM
