Throttle body question/TPS
Old Jan 15, 2008 | 09:45 AM
valentine97's Avatar
Default Throttle body question/TPS
i put my finger over the top hole in the throttle body and it lowers my idle to 1000rpm right where it needs to be and still it throws me a throttle position sensor code 7...what is my problem????
Old Jan 15, 2008 | 09:49 AM
ek-g6's Avatar
Default Re: Throttle body question/TPS (valentine97)
what engine do you have? and what throttle body has a hole on top, are you talking about the map sensor hole or something?
Old Jan 15, 2008 | 09:53 AM
Default Re: Throttle body question/TPS (ek-g6)
got a d15b and in the throttle body when u take your air intake off there are to port holes inside it and if u put ur finger over the first one it will idle at 1000 but if u dont got ur finger over it then it idles at 2500...
Old Jan 15, 2008 | 09:54 AM
rust_free_civic's Avatar
Code 7 is a bad TPS or the wiring to it. If you had the TPS off its possible the tab is not inside the prongs. This my brake the sensor.
Old Jan 15, 2008 | 09:58 AM
Default Re: Throttle body question/TPS (rust_free_civic)
when i put the voltmeter to the wiring it all has power but if i turn the ignition on and move the tps then it will not read anything... so i am thinkin the wiring is good but i dont know about the tps is it supposed to give me a reading without it plugged in and the ignition on?
Old Jan 15, 2008 | 10:00 AM
If you're sure about the wiring its a bad sensor.
Old Jan 15, 2008 | 10:02 AM
If your Tps isnt adjusted right it will NOT throw a code.
Old Jan 15, 2008 | 10:05 AM
mortificationrock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by valentine97 &raquo;</TD></TR><TR><TD CLASS="quote">i put my finger over the top hole in the throttle body and it lowers my idle to 1000rpm right where it needs to be and still it throws me a throttle position sensor code 7...what is my problem????</TD></TR></TABLE>
Your finger is TOO FAT!!!! Sorry ijust had to anyways what he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rust_free_civic &raquo;</TD></TR><TR><TD CLASS="quote">If you're sure about the wiring its a bad sensor.</TD></TR></TABLE>
X2
Old Jan 15, 2008 | 10:07 AM
this one is a brand new tps and i dont understand it but i guess i could try another throttle body to see if that will help...what do u think?
Old Jan 15, 2008 | 10:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by valentine97 &raquo;</TD></TR><TR><TD CLASS="quote"> this one is a brand new tps and i dont understand it but i guess i could try another throttle body to see if that will help...what do u think?</TD></TR></TABLE>
What exactly are you trying to fix??? If its your IDLE that your trying to fix, fix it with the Idle screw.Also check to make sure the throttle cable isnt making the throttle plate stay open! As in adjust you throttle cable with the nuts that are on it! Hope that helps
Old Jan 15, 2008 | 10:13 AM
Is your wiring harness stock, untouched? Was the wiring changed at anytime?
Old Jan 15, 2008 | 10:19 AM
yeah it has...
Old Jan 15, 2008 | 10:20 AM
Well, I bet its your wiring then. What year is the car?
Old Jan 15, 2008 | 10:21 AM
97Ej6mike's Avatar
Lowering an idle by putting your hand or finger over something indicates a vaccum leak.
Old Jan 15, 2008 | 10:23 AM
Default Re: (97Ej6mike)
its a 97 honda civic ex..my girls car an she got this d15b from h motors online...
Old Jan 15, 2008 | 10:26 AM
Default Re: (valentine97)
Im sure they unbolted the tps to ship it. Are you sure it was installed correctly? If the tab from the tps is NOT inside the 2 prongs on the throttle body it may have broke the sensor.
It happened to me once
Old Jan 15, 2008 | 10:28 AM
Can you post pics of the plug and wiring?
Old Jan 15, 2008 | 10:30 AM
Default Re: (rust_free_civic)
jus changed everything an put new tps on an its still doin the same thing?????
Old Jan 15, 2008 | 10:32 AM
I pm'ed you
Old Jan 15, 2008 | 10:33 AM
black bandit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">Lowering an idle by putting your hand or finger over something indicates a vaccum leak.</TD></TR></TABLE>
X2, Also check your iacv.
Em1Trevor
Oct 29, 2015 10:09 PM
aasaa666
Jun 29, 2008 08:13 PM
hondaokie
Jan 14, 2005 01:28 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
