Moving part contact noise
Old Jan 15, 2008 | 09:13 AM
tico's Avatar
Default Moving part contact noise
hey guys i have thiss 88 hatch and just recently it started making this noise while im driving. nothing at a stop. its coming from the middle to the right side of the car. im pretty much scared to drive it fearing that i will wear out something important. any ideas? oh it got a littl worse after a hit a small bump in the road. please help soon thnx alot guys
Old Jan 15, 2008 | 09:24 AM
pdx_503's Avatar
Default Re: Moving part contact noise (tico)
Did you check the cv joints? Is the rubber boot caked with grease or is it dry?
Old Jan 15, 2008 | 10:16 AM
tico's Avatar
Default Re: Moving part contact noise (pdx_503)
their brand new they might have 2500k on them
Old Jan 15, 2008 | 10:35 AM
JustAnotherRex's Avatar
Check your wheel bearings in the trailing arms.
Old Jan 15, 2008 | 10:41 AM
pdx_503's Avatar
Default Re: (JustAnotherRex)
They may be new cv joints but that doesn't mean they havent already went bad.
Old Jan 15, 2008 | 10:45 AM
SIred91's Avatar
Rainman
Check your tie rod ends and ball joints, and steering rack end links.
Old Jan 15, 2008 | 03:34 PM
tico's Avatar
okay. my cv joints are dry. absolutly no greas on them what so ever. oh also the camber looks to be about -1 degree or so. would that have a dramatic difference. let me put it this way the noise is so loud it over powers my radio and i can feel the vibrations anything passed 35mph. the noise sounds like when u see those lifted trucks with som big *** tires on. that noise from the rubber on the pavement as they pass u by. maybe that will help make it ckear the of the noise coming from my hatch
Old Jan 15, 2008 | 03:38 PM
SIred91's Avatar
Rainman
Default Re: (tico)
input shafts on the axles going into the tranny or the carrier bearing....it sounds like a worn out bearing man, do not make it worse.
Old Jan 15, 2008 | 03:41 PM
tico's Avatar
Default Re: (SIred91)
so it could be the bearing in the tranny where the drive shaft would be inserted? if so do u know where i could pick up a replcement bearing?
JDMPR
Mar 25, 2013 08:40 PM
eglover20
May 3, 2010 10:50 AM
aZnAcCoRd02
May 3, 2006 10:36 PM
chrisw
Mar 26, 2004 08:07 AM
Matgallis
Feb 20, 2004 07:21 AM
