how thick is too thick for trans fluid?
Old Jan 15, 2008 | 08:16 AM
redboy183's Avatar
Default how thick is too thick for trans fluid?
hey guys i have a ls trans on my b16 and ocationally it has a small grind in 3rd at around 8 grans when i get on it...and i was curious bc i was looking at the penzoil/gm snycromesh stuff but my buddy told me to go thicker but that didnt make sense to me bc would the gears like literally fry or break with thick oil in the gearbox??....and isnt the snycromesh around 10-40 weight?
SFlCrx's Avatar
HMTF ftw
Old Jan 15, 2008 | 08:23 AM
twiztid17thninja's Avatar
Default Re: (SFlCrx)
in case you didn't catch that he said use honda manual transmission fluid. for the win. hmtf is a much wider viscosity range like 10 w 60 but that isn't really a proper description either use it 7 dollars a qt but you only need like 2 anyway
Old Jan 15, 2008 | 08:28 AM
redboy183's Avatar
Default Re: (twiztid17thninja)
i hear where your commin from but i was just curious about that syncromesh stuff for grinds
Old Jan 15, 2008 | 08:31 AM
Default Re: (redboy183)
fluid is not a replacement for parts replace the syncros or just get a different transmission then run the hmtf
Edit:if it isn't that bad you could just be carful about shifting into third till you have the time to do the work.
Old Jan 15, 2008 | 12:32 PM
sanimalp's Avatar
$cat /dev/urandom
to actually fix the problem, you could scuff the gear cone for 2nd,3rd, and 4th gears.. that should make your problem go away all together. and best of all, its free if you already own some fine grit sandpaper..
Old Jan 15, 2008 | 12:35 PM
Ass$nyper's Avatar
Pirate General...YARRRR
To fix it yes you need to replace parts in the tranny to mask it sncryomesh or HMTF works great.
Personally, people now tend to know those fuilds because they assume its only used to mask gear issues, when it's a great fulid and i think everyone should use it.
Old Jan 15, 2008 | 12:56 PM
GSX 4G63T's Avatar
When I buy b series cable or hydro trannies. THe first thing I do is crack them open and inspect the bearing and gears and idler. That's it. Then I disassembly the parts that need replacement. After that I lube them up with 5w 30 and fill her up with HONDA genuine manual tranny oil.
Old Jan 15, 2008 | 01:06 PM
Ermil's Avatar
Default Re: (4163175587)
1 qt left stuff, rest right stuff
Old Jan 15, 2008 | 01:08 PM
GSX 4G63T's Avatar
My B series transmission fill to 2.9 qts. Its a J1
Old Jan 15, 2008 | 06:15 PM
eda6's Avatar
Default Re: how thick is too thick for trans fluid? (redboy183)
i was searching for info about bad needle bearings and stumbled across this.
looks like you could fry your needle bearings if the oil is too thick.
http://books.google.com/books?...50,M1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">to actually fix the problem, you could scuff the gear cone for 2nd,3rd, and 4th gears.. that should make your problem go away all together. and best of all, its free if you already own some fine grit sandpaper.. </TD></TR></TABLE>
true. i used 120 grit.
scuffed vs.unscuffed
Old Jan 15, 2008 | 06:31 PM
redboy183's Avatar
Default Re: how thick is too thick for trans fluid? (eda6)
wow that helped A LOT...thanks to everyone
joshsayswhatt
Honda Civic (2006 - 2015)
21
Jan 11, 2011 09:53 PM
TMC_EF
Dec 13, 2007 05:44 PM
Aquafina
Jan 28, 2006 05:07 PM
92integraVTECgsr
Jul 30, 2005 02:49 PM
Rah Rah
Dec 25, 2001 03:18 PM
