trunk leak in 95 del sol
My trunk seems to have a leak. There is always condensation inside the the trunk lid, and some water on floor. Does the trunk need to be insulated? Is this a common problem? Do the trunks leak on del sols often? Thanks, Julie
well my question is there like water lots of it or just a little like under the spare and stuff if its a puddle you have a bad rubber seal around the trunk lid or you tail lights have a gap some where
thanks blue, its a little bit of water. but the inside of the trunk lid has condensation on it. I read it might be leaking around the antenna opening. just wanted to see if it was a common problem. I once saw another del sol with dew inside the trunk lid.
yea that is another place to that it's known to come in at my best advice is to take it to you local dealer and have them check it further becasue they would have the right tools to fix the situation.
hermanssol
Jan 26, 2008 05:42 PM
97grnrs
Jan 2, 2006 11:07 AM
HondaHeddie
Dec 7, 2005 01:11 PM
Squallie
Sep 30, 2005 03:36 PM
