del sol Leaky trunk, good rubber, no rust
I have a 95 del sol s with a trunk that has mold growing in it from constant leaking.
I have checked the rubber, checked for rust, and all looks good.
Where else should I check for leaks?
Re: del sol Leaky trunk, good rubber, no rust (aal)
my ek hatch was leaking, i had no idea where... found out it was leaking from my tail lights. I dont know exatly how the sol's tails are set up, but i put a bead of caulk around the behind of both of my tails and it stopped my leak. good luck.
Re: del sol Leaky trunk, good rubber, no rust (BigRonDawg)
If you take off the bumper, (underneath the taillights) there should be to black looking box (I’m not sure what they are called) but they allow air in and out of your trunk. Take off, silicon, push back in, silicon around it and you should be fine.
It this doesn’t work, and you still leak. dry it up and tell me where your water is.
Re: del sol Leaky trunk, good rubber, no rust (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two »</TD></TR><TR><TD CLASS="quote">replace your trunk sail clips.</TD></TR></TABLE>
If you mean the "spoiler", I dont have one. Flat trunk
sail panels is what i think hes talking about. When you look at the back of the car, its the plastic parts that are right on the side of the windwo, looks like a sail that goes from the roof to the trunk area. I got that too like i got water droplets allllll over the top of the inside of my truck, and they froze over. Other than sail panels and the vent hole, any other areas that could make water get in a del sol trunk?
no, i'm not talking about a spoiler.
don't know if i can do this, but helping is helping...
http://www.teamdelsolwa.com/howto/trunkleak.htm
http://www.teamdelsolwa.com/howto/trunkleak2.htm
take your pillar covers off (the peices that run down the b pillar). there is two holes that they cover up that should have a peice of rubber in. normally they wear out or just fall out due to shitty manufacturing. anyways fill up the hole with some calk or whever you choose, it will fix the leak, same thing has happened to hundreds of us sol owners on solsociety.com and that is the fix we have come up with.
Here are the how to's you need to take a look at to fix the proplem. No other threads needed
hermanssol
01-26-2008 05:42 PM
Del Sol on Steroids
10
07-12-2007 04:15 PM
97grnrs
01-02-2006 11:07 AM
Squallie
10-30-2005 10:26 PM
