timing blet broke
Old Jan 14, 2008 | 06:47 PM
07crf250's Avatar
Default timing blet broke
what all is prolly broke if the timing blet broke in a d16z6 motor some one said prolly bent push rods and some more **** is that true
Old Jan 14, 2008 | 06:51 PM
ek-g6's Avatar
Default Re: timing blet broke (07crf250)
how fast were you going when this happened?
Old Jan 14, 2008 | 06:54 PM
hall97civic's Avatar
your engine doesn't have any push rods, you have an overhead cam. You propably bent a couple of valves and possibly ruined a piston and a rod. GEt a new belt, set time, put the belt on and try turing it over by had with the sparkplugs out before you go and tear everything apart. maybe you got lucky.
later.
ek-g6's Avatar
Default Re: timing blet broke (boosted_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">look for some bent valves </TD></TR></TABLE>
if you were going too fast you probably got bent valves, if you went slow enough...you might be able to get away with nothing bent or broken..get it checked
Old Jan 14, 2008 | 06:56 PM
boosted_EM1's Avatar
Old Jan 14, 2008 | 07:01 PM
07crf250's Avatar
well i can buy the hole car for 225 dollars its a 92 civic 4 door with the d16z6 coil overs and some other stuff so sould i get and how much would a head cost me
Old Jan 14, 2008 | 07:04 PM
ek-g6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 07crf250 &raquo;</TD></TR><TR><TD CLASS="quote">well i can buy the hole car for 225 dollars its a 92 civic 4 door with the d16z6 coil overs and some other stuff so sould i get and how much would a head cost me </TD></TR></TABLE>
damn thats hella cheap, if the motor was still good. the head is about 130 over here, but thats a good *** deal even for a 4-door civic.
udog1125
Sep 14, 2016 03:15 AM
misha
15
Nov 12, 2006 02:16 PM
guy_from_nerk
May 12, 2006 11:29 PM
EKB18BPR3
May 31, 2004 02:34 PM
V7echnic
Mar 14, 2004 10:05 AM
